How to remove headlights? |
andreic |
May 1 2020, 07:47 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I ordered a couple of days ago the LED H4 headlights for my 1972 914. Unfortunately, today when I tried to remove the silver ring holding the glass housing, none of the 3 screws would move at all. Their heads are somewhat rusted, and the screwdriver stripped them right away. (I did put WD-40 before on the screws, and used the right size screwdriver, even used some valve grinding compound... no luck.) What should I do at this point? Can the screws be drilled out without damaging the unit badly? I would be happy to drill them out slightly bigger, and to put some screws with nuts on the other side, but not sure this idea would work. Thanks! Andrei. |
bdstone914 |
May 1 2020, 09:47 PM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I replace them with SS socket head allen screws.
Yes you can remove the whole assembly but will need to realign everything. . Drill or grind off the heads and use vise grips on the part of the screw that protrudes thru the housing. And start with a good rust penetrant. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:01 PM |
