Shifter woes, R, 2nd and 4th only |
BPic |
May 2 2020, 03:00 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Evening everyone,
Ok, I used Dr. Evils notes - no luck. Used Racer Chris's bungee method and I got r,2,4th only. Was thinking the trans must just be screwed and adjusted way out of synch and got 1st 3rd and 5th! But no R,2,or 4. I looked under the car with it in neutral and it appears that the shaft connection at the firewall is stopping it for moving any further to catch 1,3 and 5 when it is the correct position. (IMG:style_emoticons/default/headbang.gif) Back story: I did replace inside and outside firewalls and added Tangerine Racing's shift bushing. It looks like if I removed the bushing and added the stock bushing it should have enough clearance. Has anyone had this issue with Tangerine's bushings? Will removing it help or is there a bigger issue? Or am I just an idiot and didn't follow the directions? (IMG:style_emoticons/default/confused24.gif) Wanted to get the brain trusts input before I cut off the bushing. I do have a stock plastic bushing that I can install. Here's a photo with the car in neutral. If I pull on the shifter it needs to move forward from where it is now. Cheers all!! (IMG:style_emoticons/default/beerchug.gif) |
Mblizzard |
May 2 2020, 04:21 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
What year is the car? When I did N.Y. bushing change I had to take some material off the shift knuckle at the firewall.
Don’t know what kind of bolt is jammed in the knuckle but it is not stock and could. E part of the issue as well. |
BPic |
May 2 2020, 04:24 PM
What year is the car? When I did N.Y. bushing change I had to take some material off the shift knuckle at the firewall. Don’t know what kind of bolt is jammed in the knuckle but it is not stock and could. E part of the issue as well. Bolt came with the transmission. It's identical except for the head. Car is a 72. Thanks. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:14 AM |
