Evening everyone,
Ok, I used Dr. Evils notes - no luck. Used Racer Chris's bungee method and I got r,2,4th only. Was thinking the trans must just be screwed and adjusted way out of synch and got 1st 3rd and 5th! But no R,2,or 4.
I looked under the car with it in neutral and it appears that the shaft connection at the firewall is stopping it for moving any further to catch 1,3 and 5 when it is the correct position.
Back story: I did replace inside and outside firewalls and added Tangerine Racing's shift bushing.
It looks like if I removed the bushing and added the stock bushing it should have enough clearance. Has anyone had this issue with Tangerine's bushings? Will removing it help or is there a bigger issue? Or am I just an idiot and didn't follow the directions?
Wanted to get the brain trusts input before I cut off the bushing. I do have a stock plastic bushing that I can install.
Here's a photo with the car in neutral. If I pull on the shifter it needs to move forward from where it is now.
Cheers all!!
