Shifter woes, R, 2nd and 4th only |
BPic |
May 2 2020, 03:00 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Evening everyone,
Ok, I used Dr. Evils notes - no luck. Used Racer Chris's bungee method and I got r,2,4th only. Was thinking the trans must just be screwed and adjusted way out of synch and got 1st 3rd and 5th! But no R,2,or 4. I looked under the car with it in neutral and it appears that the shaft connection at the firewall is stopping it for moving any further to catch 1,3 and 5 when it is the correct position. (IMG:style_emoticons/default/headbang.gif) Back story: I did replace inside and outside firewalls and added Tangerine Racing's shift bushing. It looks like if I removed the bushing and added the stock bushing it should have enough clearance. Has anyone had this issue with Tangerine's bushings? Will removing it help or is there a bigger issue? Or am I just an idiot and didn't follow the directions? (IMG:style_emoticons/default/confused24.gif) Wanted to get the brain trusts input before I cut off the bushing. I do have a stock plastic bushing that I can install. Here's a photo with the car in neutral. If I pull on the shifter it needs to move forward from where it is now. Cheers all!! (IMG:style_emoticons/default/beerchug.gif) |
porschetub |
May 2 2020, 05:12 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Don't believe that's the issue,the OP has simply run out of fwd movement,the TR bush robs a little space but not enough to cause this.
Lo-Fi Version | Time is now: 1st June 2024 - 12:58 AM |
