> Engine timing 2.0L, Calling all engine tuners
R Dub
post May 3 2020, 08:33 AM
I need to know what the correct timing for a 2.0L (built to 2056) with and electronic ignition, no vacuum advance running dual carbs.
I set the timing to 27 degrees BTDC per the manual but it doesn't run right, it seems much happier with some timing taken out. Any help is greatly appreciated. Thanks in advance.
Gatornapper
post May 3 2020, 08:53 AM
While 27 deg. BTDC is correct, many suggest running at 30 to 32 deg. advance. I'm running 32 deg. with dual IDF-44's on a stock 2.0, and it loves that setting.......
What distributor are you running?
What is your advance at idle?
GN
- Lo-Fi Version Time is now: 11th August 2026 - 05:11 AM
