| drem914 |
Oct 7 2017, 05:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
Just purchased a clock as part of group of center console gauges online from someone that said it was working when they pulled the console out. It was the only one of the three (volt and temp) that was not all scratched up. It was completely frozen. Now I have 2 that don't work (IMG:style_emoticons/default/headbang.gif)
I went to North Hollywood Speedo and they said "Service on these can range from $195 to $385. 1-5 day turn around." I don't need a clock that bad.... Anyone have recommendation for a reasonable repair on the center console clock? (later model) |
| bbrock |
May 3 2020, 04:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Deleted. Comment doesn't apply to this clock.
| Superhawk996 |
May 3 2020, 04:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,735 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Be aware the solder on the two legs that pop apart is low temperature and acts as a fuse to safeguard the clock when the mechanics gum up enough to increase resistance. There is a sticker on the back of the clock indicating solder temp. If you use regular solder, the clock may eventually fry if it gums up again. I fixed mine simply by remelting the low temp solder that was originally there and soldered the legs back together. It cost me only the electricity for the soldering station. @bbrock That one is a later model quartz unit. I'm not sure if they have the same solder "fuse" that we have on our earlier mechanical VDO Kienzle units. @Lmaze I've never worked on a quart unit so advice is worth what you paid. Electrolytic capacitors (the can type) go bad over time as you've already discovered. The electrolyte in them dries out and the no longer act as a capacitor. Alternatively, they swell and explode / leak as looks like is the case with yours. The electrolyte is corrosive so the lead that looks fried might just corroded away and not "fried" without any other damage. The capacitors are the prime suspects for sure. The other thing to look at if you're not alreay aware, is the copper board trace that might be below or near the capacitor. Not uncommon for the electrolyte to corrode that trace away too, but, that can usually be fixed with a jumper wire if necessary. Please post with followup on how this works out. |
| bbrock |
May 3 2020, 05:15 PM
Be aware the solder on the two legs that pop apart is low temperature and acts as a fuse to safeguard the clock when the mechanics gum up enough to increase resistance. There is a sticker on the back of the clock indicating solder temp. If you use regular solder, the clock may eventually fry if it gums up again. I fixed mine simply by remelting the low temp solder that was originally there and soldered the legs back together. It cost me only the electricity for the soldering station. @bbrock That one is a later model quartz unit. I'm not sure if they have the same solder "fuse" that we have on our earlier mechanical VDO Kienzle units. My bad. I didn't catch that. Thanks for pointing it out. (IMG:style_emoticons/default/beer.gif) |
drem914 914 clock repair? Oct 7 2017, 05:03 PM
914 7T3
Just purchased a clock as part of group of center... Oct 7 2017, 05:24 PM
jack20 PM me. Oct 8 2017, 12:25 AM
Elliot Cannon Hah! Who needs a clock when you have one of th... Oct 8 2017, 12:41 AM
worn
Hah! Who needs a clock when you have one of t... Oct 8 2017, 09:06 AM
914 7T3
Hah! Who needs a clock when you have one of ... Oct 8 2017, 12:36 PM
Mikey914 Just putting this out there, but may be worth a pe... Oct 8 2017, 02:27 PM
Mike Bellis I repaired a VW T3 clock by opening it. The clock ... Oct 8 2017, 02:40 PM
Mikey914 My thoughts exactly. You started with a broken clo... Oct 8 2017, 02:47 PM
StarBear
My thoughts exactly. You started with a broken cl... May 3 2020, 01:04 PM
Lmaze I keep telling my wife, "What am I going to d... May 3 2020, 01:13 PM
914Sixer Isn't there something over at Pelican about fi... Oct 8 2017, 06:51 PM
Coondog
Isn't there something over at Pelican about f... Oct 8 2017, 09:16 PM
Nogoodwithusernames
1973 Porsche 914 Clocks
The 1973 and very early ... Oct 9 2017, 01:37 PM
914 7T3 NoHo Speedo changes the movement of all clocks to ... Oct 8 2017, 10:06 PM
914Tom Depending on the malfunction .
If the Clock still ... Oct 9 2017, 12:13 AM
drem914 The hands, for the original one, that is still in ... Oct 9 2017, 09:47 PM
914bub
The hands, for the original one, that is still in... Sep 15 2018, 06:25 AM
North Coast Jim
The hands, for the original one, that is still in... Sep 15 2018, 07:43 AM
914bub
The hands, for the original one, that is still i... Sep 15 2018, 07:58 AM
North Coast Jim
Just purchased a clock as part of group of center... Sep 15 2018, 07:40 AM
dr914@autoatlanta.com right now we are in the process of making a reprod... Sep 15 2018, 08:43 AM
914bub
right now we are in the process of making a repro... Sep 15 2018, 10:06 AM
dr914@autoatlanta.com you have not seen a pic of our oil temp gauge yet ... Sep 15 2018, 10:29 AM
914bub
you have not seen a pic of our oil temp gauge yet... Sep 15 2018, 10:51 AM
Coondog
right now we are in the process of making a repro... Sep 15 2018, 10:43 AM
dr914@autoatlanta.com Yup, Coon, that guy in India (he is a good guy) wa... Sep 15 2018, 11:44 AM
914werke any update? Oct 23 2018, 04:38 PM
914werke :confused: Dec 11 2018, 11:59 AM
Porschef :hopper: :hopper:
I looked into finding a smal... Dec 11 2018, 12:10 PM
dr914@autoatlanta.com we had an in person meeting with our manufacturer ... Dec 11 2018, 12:20 PM
drem914 Just saw this pop back up. I didn't realize I ... Dec 11 2018, 12:54 PM
Lmaze 1974 914 2.0 Clock Repair - I removed my clock fac... May 3 2020, 12:33 PM
Lmaze I forgot to mention you do not need to take any ot... May 3 2020, 12:40 PM
Lmaze Update: I picked up the new capacitors today (16V ... May 4 2020, 03:11 PM
Superhawk996
My bad. I didn't catch that. Thanks for p... May 3 2020, 05:37 PM
Lmaze Capacitors commonly deteriorate over time. I'm... May 3 2020, 06:35 PM
bbrock
Capacitors commonly deteriorate over time. I... May 3 2020, 07:36 PM
Superhawk996 :headbanger:
Nice job. Glad it's working an... May 4 2020, 05:21 PM
Lmaze
:headbanger:
Nice job. Glad it's working a... May 4 2020, 05:47 PM
Lmaze
:headbanger:
Nice job. Glad it's working ... May 4 2020, 05:49 PM
jhynesrockmtn I know there are a few threads out there on clocks... Feb 15 2023, 08:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:49 AM |
