> 914 clock repair?, reasonable recommendation
drem914
post Oct 7 2017, 05:03 PM
Just purchased a clock as part of group of center console gauges online from someone that said it was working when they pulled the console out. It was the only one of the three (volt and temp) that was not all scratched up. It was completely frozen. Now I have 2 that don't work (IMG:style_emoticons/default/headbang.gif)
I went to North Hollywood Speedo and they said "Service on these can range from $195 to $385. 1-5 day turn around."
I don't need a clock that bad....
Anyone have recommendation for a reasonable repair on the center console clock? (later model)
bbrock
post May 3 2020, 04:28 PM
Deleted. Comment doesn't apply to this clock.
Superhawk996
post May 3 2020, 04:59 PM
QUOTE(bbrock @ May 3 2020, 06:28 PM) *
Be aware the solder on the two legs that pop apart is low temperature and acts as a fuse to safeguard the clock when the mechanics gum up enough to increase resistance. There is a sticker on the back of the clock indicating solder temp. If you use regular solder, the clock may eventually fry if it gums up again. I fixed mine simply by remelting the low temp solder that was originally there and soldered the legs back together. It cost me only the electricity for the soldering station.
@bbrock
That one is a later model quartz unit. I'm not sure if they have the same solder "fuse" that we have on our earlier mechanical VDO Kienzle units.
@Lmaze
I've never worked on a quart unit so advice is worth what you paid.
Electrolytic capacitors (the can type) go bad over time as you've already discovered. The electrolyte in them dries out and the no longer act as a capacitor. Alternatively, they swell and explode / leak as looks like is the case with yours. The electrolyte is corrosive so the lead that looks fried might just corroded away and not "fried" without any other damage. The capacitors are the prime suspects for sure.
The other thing to look at if you're not alreay aware, is the copper board trace that might be below or near the capacitor. Not uncommon for the electrolyte to corrode that trace away too, but, that can usually be fixed with a jumper wire if necessary.
Please post with followup on how this works out.
bbrock
post May 3 2020, 05:15 PM
QUOTE(Superhawk996 @ May 3 2020, 04:59 PM) *
@bbrock
My bad. I didn't catch that. Thanks for pointing it out. (IMG:style_emoticons/default/beer.gif)
Superhawk996
post May 3 2020, 05:37 PM
QUOTE(bbrock @ May 3 2020, 07:15 PM) *
What do I know . . . . I'm only guessing too since I've never actually worked on the quartz version (IMG:style_emoticons/default/confused24.gif)
It's the internet though . . . advice is always worth what was paid!
(IMG:style_emoticons/default/av-943.gif)
Lmaze
post May 3 2020, 06:35 PM
Capacitors commonly deteriorate over time. I'm not an electronic tech, but I am an electrician and have seen many capacitors fail. I have removed the capacitor, the board will be cleaned with contact cleaner prior to soldering the new legs in place. My assumption is that these two capacitors provide the regulated burst of voltage the motors requires to turn the gears. Technically they store and release a charge voltage as needed. I can't see them being used as a fuse connection. You could attribute the fine solder lines as a fuse point. I don't see any other issue other than a failed capacitor that feeds gated voltage to the motor. My solder iron is a small hobby unit, which for the most part takes forever to heat up and holds a solder melt for about a second when directly applied. I'm not concerned at this point about and heat related issued that would extend to the motor.
That being said we will soon find out when I install the new capacitor and fire up the clock. Hopefully this fix is viable.
drem914   914 clock repair?   Oct 7 2017, 05:03 PM
914 7T3   Just purchased a clock as part of group of center...   Oct 7 2017, 05:24 PM
jack20   PM me.   Oct 8 2017, 12:25 AM
Elliot Cannon   Hah! Who needs a clock when you have one of th...   Oct 8 2017, 12:41 AM
worn   Hah! Who needs a clock when you have one of t...   Oct 8 2017, 09:06 AM
914 7T3   Hah! Who needs a clock when you have one of ...   Oct 8 2017, 12:36 PM
Mikey914   Just putting this out there, but may be worth a pe...   Oct 8 2017, 02:27 PM
Mike Bellis   I repaired a VW T3 clock by opening it. The clock ...   Oct 8 2017, 02:40 PM
Mikey914   My thoughts exactly. You started with a broken clo...   Oct 8 2017, 02:47 PM
StarBear   My thoughts exactly. You started with a broken cl...   May 3 2020, 01:04 PM
Lmaze   I keep telling my wife, "What am I going to d...   May 3 2020, 01:13 PM
914Sixer   Isn't there something over at Pelican about fi...   Oct 8 2017, 06:51 PM
Coondog   Isn't there something over at Pelican about f...   Oct 8 2017, 09:16 PM
Nogoodwithusernames   1973 Porsche 914 Clocks The 1973 and very early ...   Oct 9 2017, 01:37 PM
914 7T3   NoHo Speedo changes the movement of all clocks to ...   Oct 8 2017, 10:06 PM
914Tom   Depending on the malfunction . If the Clock still ...   Oct 9 2017, 12:13 AM
drem914   The hands, for the original one, that is still in ...   Oct 9 2017, 09:47 PM
914bub   The hands, for the original one, that is still in...   Sep 15 2018, 06:25 AM
North Coast Jim   The hands, for the original one, that is still in...   Sep 15 2018, 07:43 AM
914bub   The hands, for the original one, that is still i...   Sep 15 2018, 07:58 AM
North Coast Jim   Just purchased a clock as part of group of center...   Sep 15 2018, 07:40 AM
dr914@autoatlanta.com   right now we are in the process of making a reprod...   Sep 15 2018, 08:43 AM
914bub   right now we are in the process of making a repro...   Sep 15 2018, 10:06 AM
dr914@autoatlanta.com   you have not seen a pic of our oil temp gauge yet ...   Sep 15 2018, 10:29 AM
914bub   you have not seen a pic of our oil temp gauge yet...   Sep 15 2018, 10:51 AM
Coondog   right now we are in the process of making a repro...   Sep 15 2018, 10:43 AM
dr914@autoatlanta.com   Yup, Coon, that guy in India (he is a good guy) wa...   Sep 15 2018, 11:44 AM
914werke   any update?   Oct 23 2018, 04:38 PM
914werke   :confused:   Dec 11 2018, 11:59 AM
Porschef   :hopper: :hopper: I looked into finding a smal...   Dec 11 2018, 12:10 PM
dr914@autoatlanta.com   we had an in person meeting with our manufacturer ...   Dec 11 2018, 12:20 PM
drem914   Just saw this pop back up. I didn't realize I ...   Dec 11 2018, 12:54 PM
Lmaze   1974 914 2.0 Clock Repair - I removed my clock fac...   May 3 2020, 12:33 PM
Lmaze   I forgot to mention you do not need to take any ot...   May 3 2020, 12:40 PM
Lmaze   Update: I picked up the new capacitors today (16V ...   May 4 2020, 03:11 PM
bbrock   Deleted. Comment doesn't apply to this clock.   May 3 2020, 04:28 PM
Superhawk996   Be aware the solder on the two legs that pop apar...   May 3 2020, 04:59 PM
bbrock   [quote name='bbrock' post='2811356' date='May 3 2...   May 3 2020, 05:15 PM
Superhawk996   My bad. I didn't catch that. Thanks for p...   May 3 2020, 05:37 PM
Lmaze   Capacitors commonly deteriorate over time. I'm...   May 3 2020, 06:35 PM
bbrock   Capacitors commonly deteriorate over time. I...   May 3 2020, 07:36 PM
Superhawk996   :headbanger: Nice job. Glad it's working an...   May 4 2020, 05:21 PM
Lmaze   :headbanger: Nice job. Glad it's working a...   May 4 2020, 05:47 PM
Lmaze   :headbanger: Nice job. Glad it's working ...   May 4 2020, 05:49 PM
jhynesrockmtn   I know there are a few threads out there on clocks...   Feb 15 2023, 08:35 AM
- Lo-Fi Version Time is now: 14th March 2026 - 01:49 AM
