Look what I found at the junkyard today, Found 72 porsche |
Aefcaf |
May 3 2020, 01:27 PM
Newbie Group: Members Posts: 18 Joined: 3-May 20 From: Ohio Member No.: 24,219 Region Association: MidAtlantic Region |
Afternoon everyone, I'm back after 15 years form the 914 world. I have decided to begin building another car over the next few years and began today sourcing parts for the shelf. Came across this 19mm swaybar. Can anyone tell me what 911 it came from and if this would be a good fit for a tight front end? I'm planning on doing a subaru sti conversion to bop around town on weekends. Any suspension comments are greatly appreciated as well. I will also need help identifying some of the parts I'm finding at these local junkyards.....FYI i scored the swaybar for $15 with hardware that is not pictured.
Attached thumbnail(s) |
gandalf_025 |
May 3 2020, 02:52 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Sway Bar is an aftermarket part.
Looks to be made by a company called H+H Specialties. They were based out of Massachusetts. There are threads mentioning them if you search.... |
Aefcaf |
May 3 2020, 06:47 PM
porschetub |
May 3 2020, 06:52 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sway Bar is an aftermarket part. Looks to be made by a company called H+H Specialties. They were based out of Massachusetts. There are threads mentioning them if you search.... I thought swaybar were optional for these 914's? Yes they were but this isn't a Porsche one,if cheap enough its most likely fine but I see you are missing one drop link and "A'' arm mounting bracket? ,you could make one these. Edit,was it mounted under the car ?,if so you need the mounting brackets off the front beam or just buy the beam from the wreak if not bent. |
Aefcaf |
May 3 2020, 07:28 PM
Porschetub, i have all the mounting hardware not pictured. I just need that drop link. But otherwise for the $15 I paid, Ithought it was a deal.
Lo-Fi Version | Time is now: 7th June 2024 - 09:11 PM |
