| R Dub |
May 3 2020, 08:33 AM
Member ![]() ![]() Group: Members Posts: 126 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
I need to know what the correct timing for a 2.0L (built to 2056) with and electronic ignition, no vacuum advance running dual carbs.
I set the timing to 27 degrees BTDC per the manual but it doesn't run right, it seems much happier with some timing taken out. Any help is greatly appreciated. Thanks in advance. |
| Gatornapper |
May 3 2020, 07:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,293 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
I'm inclined to agree with Mark Henry - something else going on.
Timing should be set at 3000 rpm minimum, 3500 with some distributors. Having personally had problems with 009 dizzy's, I'm suspect of your distributor...but then, I'm biased....... What is your timing at at idle? Should be 0 deg. minimum, 7 1/2 deg. max., and steady. Starting at idle, watch your timing light - as you up your RPM to 3,000, does the timing advance steadily? or does it jump? GN |
| R Dub |
May 3 2020, 08:27 PM
I'm inclined to agree with Mark Henry - something else going on. Timing should be set at 3000 rpm minimum, 3500 with some distributors. Having personally had problems with 009 dizzy's, I'm suspect of your distributor...but then, I'm biased....... What is your timing at at idle? Should be 0 deg. minimum, 7 1/2 deg. max., and steady. Starting at idle, watch your timing light - as you up your RPM to 3,000, does the timing advance steadily? or does it jump? GN I'll ask my dad what the timing is set at idle as he was watching the timing light as I was bringing the car up in RPM. He did say the timing advances steadily, not jumping. Just that it doesn't like 27 degrees at 3500 but likes it a lot at 1000-1500 RPM |
R Dub Engine timing 2.0L May 3 2020, 08:33 AM
Gatornapper Assuming you have the correct marks, this may help... May 3 2020, 08:52 AM
Gatornapper While 27 deg. BTDC is correct, many suggest runnin... May 3 2020, 08:53 AM
Mark Henry 28 degrees for carbs, you have something else goin... May 3 2020, 09:34 AM
Ansbacher I'm running dual Dellorto-40s with Pertronix. ... May 3 2020, 10:02 AM
Mark Henry
I'm running dual Dellorto-40s with Pertronix.... May 3 2020, 10:20 AM
R Dub The engine was completely rebuilt by McMark last y... May 3 2020, 10:55 AM
rjames Are you sure you’re fan marks match the ones in ... May 3 2020, 05:06 PM
Mark Henry
I'm inclined to agree with Mark Henry - some... May 4 2020, 06:25 AM
VaccaRabite I know you said the carbs were rebuilt. But have ... May 4 2020, 07:16 AM
R Dub The timing does advance with RPM. So the fan does ... May 10 2020, 06:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 05:12 AM |
