| oakdalecurtis |
Apr 26 2017, 11:03 AM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
Finally attached an LED high mount 3rd brake light. Added a strobe module to make it really pop.
Here's a short video of it in action. If you watch it in slow mo, you can see the LED lights come on significantly before the car's incandescent brake light bulbs. https://www.youtube.com/watch?v=TaQ6msHbFbA I drilled holes in the LED side mounts so I could use small screws to attach it to the underside of the targa bar instead of just the sticky tape on it. The small holes in the curved mounts' exterior allow screwdriver access to the screws inside the mount. I had to remove the engine lid to allow my drill to fit under the targa bar to drill the small pilot holes for the mounting screws. I ran the thin LED dual wire lead up through another small hole drilled through the LED mount and into the targa bar. Then the wire goes out through a small hole drilled under the rear targa bar chrome trim. After adding a dual wire extension, I ran the wire along under the rear targa trim to the edge trim, then down under that piece. I got the wire into the engine bay through a small downward hole under the side trim and through another small hole in the engine bay side near the trunk hinge attachment point. From there it was easy to follow the existing wire harness back to the brake light connection point. I put the strobe module in-line right there. Do not ground the negative from the LED light before reaching the strobe module since the module needs both positive and negative wires in and out. Ground the negative lead coming out of the strobe module. Finally, using a piggy back connector finishes the connection to the brake light lead without cutting any harness's. Btw, here's a link to the LED light at Amazon for $1.85 and free shipping! Don't know how the can do that! http://www.ebay.com/itm/Red-14-LED-Car-Aut...Nv4&vxp=mtr And here's a link to the strobe module for $6.09 and free shipping. https://www.amazon.com/CARCHET-Strobe-Contr...e/dp/B00I4J35HY A little wire and $7.94 and you're in business! |
| Literati914 |
May 3 2020, 01:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,236 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
This one is 38949B at Summit Racing and is 12 inches long and 0.625 inch high. Mounted below the roll hoop it is not visible from the rear view mirror. @Spoke Hey, Spoke.. that one does not strobe, right? I like the dimension but would prefer a strobing unit and don't see one (in that brand) that's described as such. . |
| Spoke |
May 4 2020, 07:35 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
This one is 38949B at Summit Racing and is 12 inches long and 0.625 inch high. Mounted below the roll hoop it is not visible from the rear view mirror. @Spoke Hey, Spoke.. that one does not strobe, right? I like the dimension but would prefer a strobing unit and don't see one (in that brand) that's described as such. . @Literati914 No this one is just an LED strip. No strobing. The strobing mostly is done in standalone modules and can be quite inexpensive. The strobes just go right in between the brake wire and the LED. Easy to add anywhere in the 3rd brake light wiring between the brake light wire and the 3rd brake. I haven't looked into the brake strobes to know which ones work best. |
oakdalecurtis High Mounted 3rd Brake Strobe Light Apr 26 2017, 11:03 AM
eriqx nice work! very clean.
and super-necessary... Apr 26 2017, 11:35 AM
Mark Henry No good for me....it blocks the rear view mirror v... Apr 26 2017, 11:49 AM
oakdalecurtis
No good for me....it blocks the rear view mirror ... Apr 26 2017, 02:17 PM
Mblizzard
No good for me....it blocks the rear view mirror ... May 3 2020, 02:48 PM
BillC What about flipping it over and mounting it to the... Apr 26 2017, 04:13 PM
oakdalecurtis
What about flipping it over and mounting it to th... Apr 26 2017, 08:51 PM
RickS Rather than reinvent the wheel, buy one of these. ... Apr 26 2017, 10:19 PM
87m491 Given the small size, I was thinking double sided ... Apr 27 2017, 04:31 AM
StarBear
Rather than reinvent the wheel, buy one of these.... Apr 29 2020, 03:04 PM
RickS Pic of the light.
Apr 26 2017, 10:39 PM
mepstein Im going to try some of the little, high strength ... Apr 27 2017, 05:54 AM
anderssj
Im going to try some of the little, high strength... Apr 27 2017, 11:10 AM
Im going to try some of the little, high strengt... Apr 27 2017, 03:08 PM
Gatornapper Steve -
so how did Terri reach the brake pedal fr... Apr 30 2020, 06:59 AM
Keith914 Here is my application with a 2 foot strip inside ... Apr 27 2017, 09:00 AM
Keith914
Here is my application with a 2 foot strip inside... Apr 27 2017, 09:32 AM
Spoke
Finally attached an LED high mount 3rd brake ligh... Apr 27 2017, 10:06 AM
oakdalecurtis A couple of things to consider if you plan on addi... Apr 27 2017, 10:28 AM
Spoke
A couple of things to consider if you plan on add... Apr 27 2017, 10:40 AM
Keith914
A couple of things to consider if you plan on add... Apr 27 2017, 02:34 PM
dangrouche Hey oakldalecurtis, a trademark infringement!... Apr 27 2017, 10:41 AM
oakdalecurtis
Hey oakldalecurtis, a trademark infringement... Apr 27 2017, 10:58 AM
stugray Nice work!
I have always wanted to build one ... Apr 27 2017, 03:24 PM
anderssj
Nice work!
I have always wanted to build one... Apr 27 2017, 09:00 PM
Spoke This one is 38949B at Summit Racing and is 12 inch... Apr 27 2017, 08:16 PM
Gatornapper Jerry -
Thanks! Like that one the best!
... May 4 2020, 07:10 PM
mrholland2 These need to be retina damagingly bright. Lasers?... Apr 29 2020, 01:24 PM
ClayPerrine
These need to be retina damagingly bright. Lasers... Apr 29 2020, 01:35 PM
GregAmy I find strobing/flashing brake lights to be extrem... Apr 29 2020, 01:41 PM
oakdalecurtis
I find strobing/flashing brake lights to be extre... Apr 29 2020, 02:21 PM
RickS
I find strobing/flashing brake lights to be extre... May 4 2020, 08:14 PM
Mblizzard
I find strobing/flashing brake lights to be extr... May 5 2020, 07:32 AM
Mark Henry
[quote name='RickS' post='2811731' date='May 4 20... May 5 2020, 08:45 AM
Cairo94507 I think if you came to CA and drove around you may... Apr 29 2020, 02:51 PM
bandjoey Lots of 3rd brake light threads. Here's mine... Apr 29 2020, 06:19 PM
bandjoey Someone asked about how the wires went through the... May 2 2020, 10:20 PM
North Coast Jim Here's mine. I live is a Sumer tourist area an... May 3 2020, 10:15 AM
anderssj
Here's mine. I live is a Sumer tourist area a... May 3 2020, 11:50 AM
FlacaProductions one option for a flasher:
https://www.superbrightl... May 3 2020, 12:18 PM
Mark Henry
[quote name='Literati914' post='2811299' date='Ma... May 4 2020, 12:22 PM
FlacaProductions @Literati914 - i *believe* if you find an LED tha... May 3 2020, 03:41 PM
FlacaProductions I've ordered this from ebay - unfortunately, n... May 4 2020, 10:11 AM
rjames I just installed the 3rd brake light from Custom D... May 18 2020, 11:11 AM
ValcoOscar SSSSSHHHHHH :D :)
Narp 914 3rd Brake light.
Be... May 19 2020, 09:49 AM
mgp4591 [quote name='ValcoOscar' date='May 19 ... May 19 2020, 10:25 AM
ValcoOscar
[quote name='ValcoOscar' date='May 19... May 19 2020, 10:38 AM
mb911 This is what I have and got it from @georgerud ..... May 19 2020, 10:00 AM
FlacaProductions Straight to the rear glass - gotcha - just notch t... May 19 2020, 10:49 AM
ValcoOscar
Straight to the rear glass - gotcha - just notch ... May 19 2020, 10:57 AM
FlacaProductions Hey @ValcoOscar - correct. I wasn't talking... May 25 2020, 11:22 AM
GeorgeRud That piece will fit into an opening cut into the u... Jul 19 2020, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:47 AM |
