> Name this relay
mb911
post May 5 2020, 04:54 PM
What relay would this be? Seat belt interupter?Attached Image
lierofox
post May 5 2020, 04:59 PM
QUOTE(mb911 @ May 5 2020, 03:54 PM) *
Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay.
mb911
post May 5 2020, 05:01 PM
QUOTE(lierofox @ May 5 2020, 02:59 PM) *
Ok that helps as well.. As I figure out the 911 switch conversion..
ClayPerrine
post May 6 2020, 07:46 AM
QUOTE(mb911 @ May 5 2020, 06:01 PM) *
If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit.
With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer.
This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery.
If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this.
mb911   Name this relay   May 5 2020, 04:54 PM
lierofox   What relay would this be? Seat belt interupter? ...   May 5 2020, 04:59 PM
mb911   What relay would this be? Seat belt interupter? ...   May 5 2020, 05:01 PM
ClayPerrine   [quote name='lierofox' post='2811993' date='May 5...   May 6 2020, 07:46 AM
mb911   [quote name='lierofox' post='2811993' date='May ...   May 6 2020, 07:48 AM
ClayPerrine   [quote name='ClayPerrine' post='2812183' date='Ma...   May 6 2020, 07:53 AM
mb911   [quote name='ClayPerrine' post='2812183' date='M...   May 6 2020, 05:20 PM
ClayPerrine   [quote name='ClayPerrine' post='2812188' date='Ma...   May 7 2020, 01:06 PM
mb911   [quote name='ClayPerrine' post='2812188' date='M...   May 8 2020, 06:29 AM
GregAmy   I name it "Aloysius".   May 5 2020, 05:56 PM
bbrock   I name it "Aloysius". Sounds like as ...   May 5 2020, 06:11 PM
mb911   I like this game..   May 5 2020, 06:20 PM
raynekat   I'll call that relay "Bob."   May 5 2020, 09:46 PM
mrholland2   I'll call that relay "Bob." I did...   May 6 2020, 10:54 AM
Dave_Darling   I'll call that relay "Bob." Heh, ...   May 6 2020, 10:28 PM
mb911   Ok will do.. Maybe a day or so.   May 6 2020, 07:55 AM
ClayPerrine   I have the low/high beam and horn wiring mods figu...   May 8 2020, 08:15 AM
mb911   I have the low/high beam and horn wiring mods fig...   May 8 2020, 08:21 AM
dr914@autoatlanta.com   high low beam What relay would this be? Seat bel...   May 8 2020, 09:01 AM
ClayPerrine   New how to thread http://www.914world.com/bbs2/in...   May 8 2020, 03:03 PM
- Lo-Fi Version Time is now: 5th July 2025 - 03:01 AM
