mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,598 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
lierofox |
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California ![]() ![]() |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,422 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. |
ClayPerrine |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. I need the year of the 914, and the part number off the 911 switch. I will give you two diagrams, and a step by step set of instructions on how to do it. Clay |
Lo-Fi Version | Time is now: 5th July 2025 - 03:20 AM |
