> Picking away @ small jobs...leaking speedo drive?, how high to lift rear end to change o-ring ?
porschetub
post May 4 2020, 05:21 PM
As per question,don't want to change oil because it pisses out the hole due to wrong tilt...thinking full extension on my bigger jackstands ??.
TIA.
infraredcalvin
post May 6 2020, 05:37 PM
Distracted Member
Now that I’ve got it in hand, assuming it goes like this, inside the bushing...
Mikey914
post May 6 2020, 08:24 PM
The rubber man
QUOTE(infraredcalvin @ May 6 2020, 04:37 PM) *
You are correct that is the orientation. The seal we put out that we sent the replacement on id the one that we added. The thin one.
porschetub   Picking away @ small jobs...leaking speedo drive?   May 4 2020, 05:21 PM
RickS   Get it up as high as possible. If you have some ...   May 4 2020, 08:23 PM
Mikey914   2.7 qts is the quantity for complete refill, I...   May 5 2020, 12:02 AM
framos914   Got the new seal in the mail but 2 days too late. ...   May 5 2020, 10:53 AM
Tdskip   I’m thinking we have a new challenge here – le...   May 5 2020, 12:32 PM
914e   I’m thinking we have a new challenge here – l...   May 7 2020, 11:52 AM
infraredcalvin   Ok dumb question and no pics cause I’m at the of...   May 5 2020, 12:39 PM
dax1969   Ok dumb question and no pics cause I’m at the o...   May 6 2020, 02:22 AM
porschetub   Ok so its basically a no go then ,I will just drai...   May 5 2020, 01:36 PM
Mikey914   That looks like black seal. the brown is really br...   May 6 2020, 08:29 AM
infraredcalvin   This is the little guy I mentioned, it’s hard...   May 6 2020, 05:34 PM
infraredcalvin   Now that I’ve got it in hand, assuming it goes l...   May 6 2020, 05:37 PM
Mikey914   Now that I’ve got it in hand, assuming it goes ...   May 6 2020, 08:24 PM
dax1969   Now that I’ve got it in hand, assuming it goes...   May 7 2020, 12:27 AM
porschetub   [quote name='Mikey914' post='2812433' date='May 7...   May 7 2020, 03:14 PM
SO.O.C914er   I have the brown one and still waiting to hear/see...   May 6 2020, 06:55 PM
infraredcalvin   Installed! No drama, will check for leaks in ...   May 6 2020, 09:29 PM
Mikey914   There is no lip seal in the OEM, so my answer is a...   May 7 2020, 03:42 PM
porschetub   There is no lip seal in the OEM, so my answer is ...   May 7 2020, 08:08 PM
Mikey914   Sorry my misunderstanding when you said lip seal I...   May 7 2020, 11:47 PM
- Lo-Fi Version Time is now: 1st August 2025 - 11:03 AM
