| dgraves |
May 10 2020, 06:11 PM
1974 914 2.0 ![]() ![]() Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
Any recommendations for a louder turn signal flasher? My lever switch doesn't return after completing a turn. So, I manually have to return the lever to neutral. Unfortunately, the flasher sound is not very loud and often I leave my turn indicator on.
I tried a flasher from Turnalarm, but it was like an annoying backup beeper. Many thanks. |
| porschetub |
May 10 2020, 06:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,159 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Any recommendations for a louder turn signal flasher? My lever switch doesn't return after completing a turn. So, I manually have to return the lever to neutral. Unfortunately, the flasher sound is not very loud and often I leave my turn indicator on. I tried a flasher from Turnalarm, but it was like an annoying backup beeper. Many thanks. Simple enough ,replace the switch if the cancel tab is broken,if not check your steering wheel position ,are your indicator lights working in your tacho ?. Good idea to sort it as someone may crash into you (IMG:style_emoticons/default/dry.gif) . Good luck. |
dgraves Louder Turn signals? May 10 2020, 06:11 PM
lierofox
Any recommendations for a louder turn signal flas... May 10 2020, 06:19 PM
Stingbee My 76 turn signal lamps do flash correctly, but th... May 10 2020, 06:40 PM
Spoke
My 76 turn signal lamps do flash correctly, but t... May 10 2020, 07:05 PM
Stingbee
My 76 turn signal lamps do flash correctly, but ... May 11 2020, 12:39 PM
dgraves
My 76 turn signal lamps do flash correctly, but ... May 11 2020, 07:04 PM
bbrock I just installed an EP26 relay modified per Spoke... May 10 2020, 07:37 PM
Stingbee :headbanger: May 11 2020, 12:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th August 2026 - 04:43 AM |
