SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,711 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Installing new front and rear main seals on my '73 2.0 (rear is flywheel seal) and haven't done this for a while...
Any new tricks to make installation either easier or successful? TIA. |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,564 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
There’s footage of installing the RMS in my clutch replacement video. Link in my signature below. Rear goes on pretty easy. For the front I use some permatex aviation sealant in the bore and a piece of pvc or large socket which is about the size of the seal. tapped on lightly. You can also just use a small wood block. Jake Raby uses a soft faced hammer directly on the seal in his rebuild video.
Lo-Fi Version | Time is now: 9th July 2025 - 12:23 AM |
