Weird behavior - Gas in oil after sitting for three months, ignition on and battery drained |
Jett |
May 12 2020, 08:20 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Hello we hit a weird failure mode of gasoline in the motor oil and cannot detect any mechanical issues.
Our 73 2.0 was recently restored and engine rebuilt using NOS, refurbished, or new parts. After the car was together, we spent several months shaking out the bugs by driving->identifying issues->fixing (repeat), until it was running very well. That said, once the car was mechanically sound, I switched focus to deep cleaning and waxing the car for the first time (IMG:style_emoticons/default/smile.gif) and found a small flaw in the paint that required a visit back to the body shop. We dropped the car off before the lockdown and it sat for more than two months, before it was fixed. The problem: The body shop inadvertently left the ignition on and the new Optima battery drained out, but after charging the car it would not start. We pulled the plugs and they were soaked in gas, which lead us to check the oil. The oil was full of gas. We towed (carrier) the car to our friends shop who could not find any obvious mechanical issue, so we cleaned the plugs, replaced the oil and filter, ran the car. The car ran perfectly. We drained the oil and replaced the filter for good measure. The car is running well, no signs of injector or seal issues, and lots of power. Any theories? I thought that it could be the pump cycling on and off as the battery starts to fail / recover, but this should not cause the injectors to fire. |
GregAmy |
May 13 2020, 07:47 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Note that unless you plan to start the engine with outside temps below freezing (literally, 32F) then the CSV will never engage. Just leave the hose disconnected and plug the fuel rail fitting (914Rubber sells the screws and washers to screw into the fuel rail fitting.)
Jett |
May 13 2020, 08:32 AM
Note that unless you plan to start the engine with outside temps below freezing (literally, 32F) then the CSV will never engage. Just leave the hose disconnected and plug the fuel rail fitting (914Rubber sells the screws and washers to screw into the fuel rail fitting.) Thanks. The car is very stock, so I’d like everything working and in place, but if we cannot address then disconnecting and capping. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:33 AM |
