> Headlight Actuactor Arm, How is it held on?
BeatNavy
post May 13 2020, 03:14 PM
I'm in the process of trying to clean up / resto the headlights and headlight carriers on my '75 project car. Took one apart, treated the rust, and hit it with the gray paint. I order the rebuild kit from 914 Rubber. In looking at the driver's and passenger's side assemblies there's a difference I can't figure out, specifically with how the actuator arm is retained on the pin.
On the LEFT in the pic below, I've pointed to the assembly pin that has a hole in it (dark pic, sorry). A washer slides on the pin and a cotter pin goes through that hole to hold the washer and arm in place. The assembly on the RIGHT has no hole in the pin for a cotter to go through. So how is it held on? I took these apart so long ago I can't remember what was on there or why these were different.
Also, is it supposed to be one spring holding the carrier on the assembly or two?
TIA
914e
post May 13 2020, 03:56 PM
My later model ones do not have a cotter pin, I don't know if the early models did.
The slot in the body the arm goes though keeps it in place. You have to flex the arm to get it on the peg.
- Lo-Fi Version Time is now: 14th March 2026 - 07:36 AM
