> Do I have my cold start injector working?
gturner008
post May 15 2020, 12:13 PM
It’s me again! Newbie.
I’m almost there now, getting the 76 running sweetly. I’ve noticed on cold start, on a warm (ish) day at 10c, car starts perfectly. But immediately idles smoothly at 1000 rpm.
It does not run at 1500 rpm - as I would have thought. Then as it gets warm, dropping to 950 rpm.
Does it sound like the system for cold start isn’t working? Anything to check or anything obvious I need to check? Cheers. Gary
ndfrigi
post May 15 2020, 12:18 PM
I think your cold start is working well if you can start the engine with just turning the key. Your issue maybe the AAR that is supposed to be open when cold so it will get more air that makes the idle higher then when it is getting warm, the AAR will close and less air goes to the intake and drops the idle.
- Lo-Fi Version Time is now: 2nd July 2025 - 08:27 PM
