> Wits end...again., Rocker arm studs....wtf?
Tjmrfe
post May 14 2020, 12:24 PM
NON IMPEDING RATIONE COGITATIONIS
Ok,
Thanks in advance,
Changed my oil seals on my push rod tubes, with help fro y’all. So, I go to put the rockers back on...and strip my studs trying to put18 ft lbs of torque on them! (As per my “ how to rebuild your type 4 “ book, by Tom Wilson. So far he hasn’t lied to me...so, this happens to 3! Damn, so I order them from AA. And, wouldn’t ya know it. Trying to tighten on the studs AGAIN! I strip em. So, now I’m pisssed....now...I found a blog in samba, saying that 18 is way too much, so....I ordered another set from AA and lo and behold they stripped again with only 11 ft lbs..... I’m not doing well here.
Ready to scream...louder....
Has any one else had this? What am I doing wrong? Thank you again....
Nogoodwithusernames
post May 14 2020, 02:58 PM
Are your aluminum heads stripped or are the studs themselves stripping where the little nut holds the rocker shaft?
If the stud itself is stripping bump up to the 8mm heavy duty studs from the T4 Store (LN engineering) vs the stock 7mm stud.
Tjmrfe
post May 15 2020, 07:30 PM
QUOTE(Nogoodwithusernames @ May 14 2020, 12:58 PM) *
Thanks, yes the studs themselves, not the threads in the head ( thank God) so, that’s who I’ll try for the next round...thank you.
- Lo-Fi Version Time is now: 1st August 2025 - 07:01 PM
