| RickS |
May 20 2020, 09:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot.
So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. |
| Mikey914 |
May 20 2020, 11:37 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes now I have some time I will be getting back on that one.
The problem I personally experienced was the ground strap on the top of the transmission was corroded. The shortest path for current then became the clutch cable. Mine did that and finally broke as it was on a longer drive. So it's not just a cable issue. Might check that ground. (IMG:style_emoticons/default/smile.gif) |
RickS How often do you replace your clutch cable? May 20 2020, 09:09 PM
mountainroads
My throw is starting to feel notchy again, which ... May 20 2020, 10:16 PM
RickS
My throw is starting to feel notchy again, which... May 20 2020, 11:31 PM
ClayPerrine
I've personally experienced a cable failure w... May 21 2020, 03:01 PM
mountainroads
You don't have to leave it in one gear. If... May 21 2020, 03:34 PM
infraredcalvin Long ago, broke a clutch cable, prior to replaceme... May 20 2020, 10:37 PM
porschetub
My throw is starting to feel notchy again, which ... May 20 2020, 11:09 PM
bdstone914 @porschetub date='May 20 2020, 10:09 PM... May 21 2020, 09:38 AM
porschetub
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 21 2020, 01:25 PM
Superhawk996
Yes now I have some time I will be getting back o... May 21 2020, 11:05 AM
JamesM I replace them whenever they break or are damaged ... May 21 2020, 02:12 AM
rjames Replaced mine a within a year after getting the ca... May 21 2020, 09:11 AM
Mark Henry
Replaced mine a within a year after getting the c... May 21 2020, 10:00 AM
sixnotfour Are you using a 6 cable ?
Gemo 914-423-401-08 ... May 21 2020, 09:48 AM
StarBear
Gemo 914-423-401-08 ... May 21 2020, 11:50 AM
sixnotfour
[quote name='sixnotfour' post='2817498' date='May... May 21 2020, 01:56 PM
mepstein All the new cables need lube. I stand on a chair, ... May 21 2020, 10:53 AM
jfort This thread got me thinking about it as I had one ... May 21 2020, 02:20 PM
brcacti So are we supposed to have lots of grease on the c... May 21 2020, 08:19 PM
StarBear
So are we supposed to have lots of grease on the ... May 22 2020, 12:05 PM
Superhawk996
So are we supposed to have lots of grease on the... May 22 2020, 02:31 PM
Jmkorfha One of the leading causes of clutch cable failure ... May 23 2020, 07:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 01:39 PM |
