> 2.0 Sheet metal, 2.0 Sheet metal
Teknon
post Dec 15 2004, 09:15 AM
The more I learn the dumber i think I am
Is there a difference between the sheet metal (shroud etc.) on a 2.0 vs. a 1.7 or 1.8. (IMG:style_emoticons/default/sad.gif)
ClayPerrine
post Dec 15 2004, 09:22 AM
Simple answer... Yes. The 2.0 engine has different cylinder heads. Those heads have different spark plug angles, so the engine tin had to be remade for the 2.0. You can use the 1.7/1.8 tin if you weld up and redrill the holes for the spark plugs in the correct location for the 2.0 heads. The rest of the tin is identical.
IIRC... the 1.7/1.8 tin has a corner where the 2.0 spark plug wires have to go, so they made the 2.0 tin more rounded on top.
Keep asking questions... it's the only way to learn.
- Lo-Fi Version Time is now: 29th May 2024 - 01:55 AM
