| malcolm2 |
Oct 31 2017, 05:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I can think of a couple ways to fix this. Can i hear more ideas?
You can see that there are 4 weld impressions. 3 have pulled a hole in the firewall. ![]() |
| BeatNavy |
May 24 2020, 01:47 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Drill out those spot welds with a spot weld bit. Use a chisel or old screw driver and a hammer to break what's left of the welds and get it off the firewall, but try to be careful not to tear the firewall itself. Grind off what's left.
| 96740 |
May 27 2020, 05:57 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 10-March 08 From: Thousand Oaks, CA Member No.: 8,791 Region Association: Southern California |
Drill out those spot welds with a spot weld bit. Use a chisel or old screw driver and a hammer to break what's left of the welds and get it off the firewall, but try to be careful not to tear the firewall itself. Grind off what's left. Thank you. (IMG:style_emoticons/default/beer.gif) |
malcolm2 Engine lid hinge repair Oct 31 2017, 05:12 PM
mzalanka Tape & mask window. Wire brush to metal. Tack ... Oct 31 2017, 06:08 PM
cary It will need to be patched. Most of the time the s... Nov 1 2017, 05:40 AM
malcolm2
It will need to be patched. Most of the time the ... Nov 1 2017, 07:28 AM
cary I don't have a car to look at right now. Will ... Nov 1 2017, 08:17 AM
malcolm2
I don't have a car to look at right now. Will... Nov 1 2017, 11:44 AM
mzalanka I wouldn't second guess Cary as he obviously k... Nov 1 2017, 12:33 PM
cary How about doing a combo of your two ideas. Lets us... Nov 1 2017, 09:54 PM
malcolm2 looks like cary's combo idea might be the way ... Nov 2 2017, 05:57 PM
windforfun You might want to pull out the pad behind your sea... Nov 2 2017, 07:16 PM
malcolm2
You might want to pull out the pad behind your se... Nov 2 2017, 07:20 PM
windforfun I'm referring to the interior pad & not th... Nov 2 2017, 07:23 PM
malcolm2
I'm referring to the interior pad & not t... Nov 2 2017, 07:27 PM
windforfun Interesting. My "73 has no adhesive. In fac... Nov 2 2017, 07:33 PM
malcolm2
Interesting. My "73 has no adhesive. In fa... Nov 2 2017, 07:42 PM
windforfun BTW, the spot or tack welds just popped on one of ... Nov 2 2017, 07:45 PM
windforfun Here's the new pad. Nov 2 2017, 07:50 PM
Garold Shaffer
Here's the new pad.
I believe the pad he is... Nov 2 2017, 08:26 PM
malcolm2 Well I finally got around to finishing this projec... Nov 11 2017, 04:58 PM
cary That dog will hunt ...............
Mask it off and... Nov 11 2017, 08:05 PM
96740 I just ran into this problem too. Looks like it... May 24 2020, 01:38 PM
Rikyrat Hey, I had the same problem with my hinge cracked ... May 27 2020, 11:47 AM
dangrouche here's my technique using a piece of "L... May 28 2020, 09:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:29 AM |
