| Mikey914 |
May 29 2020, 06:13 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Ok, One of the things I've been working on are mask coverings. There are 2 options
1- N95 cover 2 -PM2.5 cover They are sewn slightly differently. The N95 has more of a point to it. These are covers for the filters. I can get the N95 masks as shown at $5 each and the PM2.5 @$1 each They are nit included unless you want them. You may be able to buy in bulk at a better price, I'm adding nothing to the cost. The coverings are $10 each and will be made to order. Your options are the Hounds tooth in Black and white Black and blue Black and yellow Black and red May do some black and green if there is demand Also I have the plaids as shown. May be limited on some quantities of different colors 1st version is the PM2.5 shown in red houndstooth Just let me know which version you want and the color. Attached thumbnail(s) Attached image(s)
| jeffdon |
May 30 2020, 08:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Are you sewing in a piece of wire over the nose bridge so you can form it for a tight fit?
| Superhawk996 |
May 30 2020, 08:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Are you sewing in a piece of wire over the nose bridge so you can form it for a tight fit? Waste of time. Cooties are very small. Coronavirus is 60-140 nano meter particle size. They will still spew in and out between the pores of the N95 filter and fabric. N95 mask material is a government efficiency rating that means the mask blocks about 95 percent of particles that are 0.3 microns in size or larger. Notice that isn't 100% blockage even under ideal conditions of use. 0.3 microns = 300 nano meters. Therefore Corona virus is 1/2 the size of what a N95 filter is able to filter. 0.3 micrometer of filtration assumes you have a PERFECT seal around the entire perimeter of the mask which isn't possible. Of course, if you have a beard, or stubble, be sure to shave that too. Otherwise what little mask seal you have is further compromised. |
Mikey914 Masks /covers IN PLAID and hound's tooth $10 May 29 2020, 06:13 PM
Mikey914 The N95 version in black and white Hound's too... May 29 2020, 06:14 PM
sb914 RE: Masks /covers IN PLAID and hound's tooth $10 May 29 2020, 06:35 PM
Larmo63 Not a mask guy.
:bullshit: May 29 2020, 06:41 PM
preach
Not a mask guy.
:bullshit:
Don't start ... May 29 2020, 06:54 PM
stevend914 ... to east bumfuck Maine. Big difference.
When ... May 29 2020, 07:05 PM
914e
When... May 30 2020, 06:44 PM
SirAndy Not a mask guy.
:bullshit:
Here we go again ...... May 29 2020, 07:53 PM
bobboinski PM sent. May 29 2020, 07:19 PM
Larmo63
Not a mask guy.
:bullshit:
Here we go again ..... May 29 2020, 07:59 PM
PanelBilly See my PM May 29 2020, 09:20 PM
mgp4591 Any other options such as the psychedelic black an... May 29 2020, 09:40 PM
flat4guy Those are great. May 29 2020, 10:13 PM
Andyrew 4 please!
Orange, and Black plaid, red hounds... May 29 2020, 10:39 PM
warpig :Qarl: Finally the silver lining in the apocalypse... May 29 2020, 10:51 PM
abes914 I like it.
Is it hard to breadth when using it?... May 29 2020, 11:11 PM
Mikey914 Material is surprisingly easy to breath through fo... May 30 2020, 01:06 AM
abes914
Material is surprisingly easy to breath through f... May 30 2020, 01:24 AM
914four Getting tired of wearing the disposable masks all ... May 30 2020, 08:24 AM
Superhawk996 I'm game for GB of plague doctor masks with N9... May 30 2020, 08:24 AM
fiacra
Are you sewing in a piece of wire over the nose ... May 30 2020, 10:25 AM
SirAndy Many pathogens, such as SARS CoV-2, are primarily ... May 30 2020, 10:37 AM
Superhawk996
All good points, but some miss the point. . . ... May 30 2020, 11:36 AM
fiacra
All good points, but some miss the point. . .... May 30 2020, 12:03 PM
Superhawk996
I think you know I meant anything REASONABLE to ... May 30 2020, 12:24 PM
SirAndy 5) Force all known HIV positive patients to wear a... May 30 2020, 12:43 PM
Superhawk996
What is it with you Americans and your obsession... May 30 2020, 01:44 PM
SirAndy When you no longer have the right to determine wha... May 30 2020, 01:53 PM
Superhawk996
When you no longer have the right to determine wh... May 30 2020, 01:55 PM
914four
Are you sewing in a piece of wire over the nose ... May 31 2020, 09:57 AM
Mikey914
Are you sewing in a piece of wire over the nose b... May 30 2020, 11:57 AM
gandalf_025 Regardless of anything else..
Fitted around the no... May 30 2020, 11:33 AM
johnlush In for a couple plaid as it has been theorized tha... May 30 2020, 11:53 AM
rhodyguy <_< :rolleyes: no good deed goes unpunished... May 30 2020, 12:20 PM
Andyrew @[url=http://www.914world.com/bbs2/index.php?showu... May 30 2020, 01:52 PM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... May 30 2020, 01:59 PM
jeffdon
You do know what asymptomatic means, right? May 31 2020, 08:52 AM
ben*james In for 5. Not because I need them so much but out... May 30 2020, 03:56 PM
silverg I would like:1 N95 Black & White, 1 PM2.5 Blac... May 30 2020, 07:29 PM
DRPHIL914 i am in for a few things , 2 plaid , a black/white... May 30 2020, 08:11 PM
Morph914 One PM 2.5 cover in Matisse blue tartan and 2 of t... May 30 2020, 08:16 PM
djway Physics informs that all things in nature follow t... May 30 2020, 09:55 PM
KELTY360
Ok, One of the things I've been working on ar... May 30 2020, 11:00 PM
MartyYeoman I'd be in for 2ea. of the N95 version in black... May 30 2020, 11:20 PM
djway #45
#80
For 2.5 May 31 2020, 12:25 AM
BPic @mikey914
These are fantastic thank you!
I... May 31 2020, 06:57 AM
Larmo63 In SoCal, wearing a mask is nothing more than virt... May 31 2020, 03:43 PM
SirAndy In SoCal, wearing a mask is nothing more than virt... May 31 2020, 05:05 PM
Superhawk996
In SoCal, wearing a mask is nothing more than vir... May 31 2020, 05:25 PM
SirAndy I don't think your beef over the holocaust was... May 31 2020, 05:44 PM
Rusty This thread is another political hot potato that w... May 31 2020, 07:37 PM
KELTY360
This thread is another political hot potato that ... May 31 2020, 07:58 PM
Mikey914 I'm not down for the politics of the situation... May 31 2020, 09:43 PM
Larmo63 I said nothing about the holocaust. I live at the... May 31 2020, 10:12 PM
SirAndy I said nothing about the holocaust. I live at the... Jun 1 2020, 10:42 AM
rhodyguy The roof is on fire.... Jun 1 2020, 08:31 AM
mbseto
The point is that life is inherently dangerou... Jun 1 2020, 08:48 AM
Literati914 :bullshit:
. Jun 1 2020, 10:46 AM
Andyrew @Mikey914
Mark,
I edited my quantities, co wor... Jun 1 2020, 11:43 AM
Optimusglen I'd be down for a black/grey plaid one if avai... Jun 1 2020, 11:59 AM
eric9144 I'd be in for 2 -PM2.5 covers in plaid 80 and ... Jun 1 2020, 02:25 PM
dlkawashima Hi Mark,
I’m in for a 2.5 houndstooth in orang... Jun 3 2020, 11:36 PM
RiqueMar My Grandfather died of COVID-19 3-weeks ago. My Mo... Jun 4 2020, 12:12 AM
914e Asking my daughters few days ago which they wanted... Jun 4 2020, 12:22 AM
Mikey914 Ok,
I've got the masks going for those so far.... Jun 4 2020, 12:59 AM
euro911 Mark ...
(1) PM2.5 B&W Houndstooth cover
(1) ... Jun 4 2020, 01:03 AM
Mikey914
Mark ...
(1)... Jun 4 2020, 01:15 AM
Front yard mechanic Let me end this thread Plaid is for sissys Jun 4 2020, 07:12 AM
ClayPerrine I have not been following this thread but I guess... Jun 4 2020, 07:35 AM
ClayPerrine For all of you that were attempting to purchase ma... Jun 4 2020, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:06 PM |
