> Oil leak repair
FJ1200
post May 30 2020, 08:28 AM
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car.
The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed.
Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car.
Thanks,
Daniel
FJ1200
post May 30 2020, 09:54 AM
Thanks,
I have not done a 901, but I have done Audi 016, 01E AND 01A as well a a 915 and a 930 box. I actually love doing trans work it makes me remember what it was like to actually fix things rather than just bolt in units. I actually just remembered that I also did all of the syncros in my X1/9 20 years ago.
By the way, 996 Superhawk, fun bike. I have a love for V/L twins as an ex Ducati owner (3 new ones). Current steed is a 1993 FJ1200 with 90k on it (bought with 6k) and an RZ350 bored and stroked to 421 with R1 suspension.
Regards,
Daniel
FJ1200   Oil leak repair   May 30 2020, 08:28 AM
Superhawk996   :wttc: Wecome to 914's. Two rules of 914...   May 30 2020, 08:43 AM
FJ1200   Thanks, for the response. I know, there has to be...   May 30 2020, 08:55 AM
Superhawk996   Thanks, for the response. I know, there has to b...   May 30 2020, 09:11 AM
FJ1200   Just checked the oil pressure switch, dry. As a ma...   May 30 2020, 09:31 AM
Superhawk996   With Porsche parts prices what they are this will...   May 30 2020, 09:44 AM
FJ1200   Thanks, I have not done a 901, but I have done Au...   May 30 2020, 09:54 AM
Superhawk996   Thanks, I have not done a 901, but I have done A...   May 30 2020, 10:05 AM
North Coast Jim   Buy the Harbor Freight hydraulic lift table. The 8...   May 30 2020, 10:07 AM
Bleyseng   :ttiwwp:   May 30 2020, 10:19 AM
FJ1200   Thanks for the input guys, money is a little tight...   May 30 2020, 10:19 AM
FJ1200   All right, I am going to attempt to post a picture...   May 30 2020, 12:12 PM
ndfrigi   All right, I am going to attempt to post a pictur...   May 30 2020, 01:08 PM
FJ1200   Well, I bit the bullet and dropped the engine/tran...   May 31 2020, 06:06 AM
Superhawk996   :cheer: :trophy:   May 31 2020, 07:47 AM
FJ1200   Miracle of all miracles, all of the oil stays in t...   Jun 2 2020, 05:33 PM
Morrie   Rather than create a new thread, I am going to jum...   Feb 8 2023, 08:14 PM
Dave_Darling   There's at least a decent chance that much of ...   Feb 8 2023, 09:00 PM
Superhawk996   Hopefully that's not a crack I see where the...   Feb 9 2023, 09:10 AM
Morrie   Hopefully that's not a crack I see where th...   Feb 9 2023, 02:12 PM
Geezer914   Nice! Love the color. With a 914 that's ...   Feb 9 2023, 06:55 AM
Superhawk996   Someone else just went through a similar leak with...   Feb 9 2023, 09:06 AM
Morrie   Someone else just went through a similar leak wit...   Feb 9 2023, 02:19 PM
bkrantz   Someone else just went through a similar leak wi...   Feb 9 2023, 08:33 PM
Superhawk996   That was me. I didn’t want to rat on you ...   Feb 9 2023, 09:00 PM
bkrantz   That was me. I didn’t want to rat on you ...   Feb 10 2023, 08:28 PM
Superhawk996   Oil pressure relief valve has no bearing on the oi...   Feb 9 2023, 02:33 PM
Morrie   Oil pressure relief valve has no bearing on the o...   Feb 9 2023, 07:58 PM
930cabman   I was chasing an oil leak at the front end and fou...   Feb 10 2023, 07:21 PM
Superhawk996   I was chasing an oil leak at the front end and fo...   Feb 10 2023, 08:24 PM
930cabman   [quote name='930cabman' post='3057145' date='Feb ...   Feb 11 2023, 07:56 AM
Superhawk996   [quote name='930cabman' post='3057145' date='Feb...   Feb 11 2023, 08:21 AM
- Lo-Fi Version Time is now: 10th November 2026 - 12:33 AM
