> Masks /covers IN PLAID and hound's tooth $10, Doing a run this next week
Mikey914
post May 29 2020, 06:13 PM
The rubber man
Ok, One of the things I've been working on are mask coverings. There are 2 options
1- N95 cover
2 -PM2.5 cover
They are sewn slightly differently. The N95 has more of a point to it.
These are covers for the filters. I can get the N95 masks as shown at $5 each and the PM2.5 @$1 each They are nit included unless you want them. You may be able to buy in bulk at a better price, I'm adding nothing to the cost.
The coverings are $10 each and will be made to order.
Your options are the
Hounds tooth in
Black and white
Black and blue
Black and yellow
Black and red
May do some black and green if there is demand
Also I have the plaids as shown. May be limited on some quantities of different colors
1st version is the PM2.5 shown in red houndstooth
Just let me know which version you want and the color.
Closed TopicStart new topic
jeffdon
post May 30 2020, 08:40 AM
Are you sewing in a piece of wire over the nose bridge so you can form it for a tight fit?
Superhawk996
post May 30 2020, 08:50 AM
QUOTE(jeffdon @ May 30 2020, 10:40 AM) *
Waste of time. Cooties are very small.
Coronavirus is 60-140 nano meter particle size. They will still spew in and out between the pores of the N95 filter and fabric.
N95 mask material is a government efficiency rating that means the mask blocks about 95 percent of particles that are 0.3 microns in size or larger. Notice that isn't 100% blockage even under ideal conditions of use.
0.3 microns = 300 nano meters. Therefore Corona virus is 1/2 the size of what a N95 filter is able to filter. 0.3 micrometer of filtration assumes you have a PERFECT seal around the entire perimeter of the mask which isn't possible.
Of course, if you have a beard, or stubble, be sure to shave that too. Otherwise what little mask seal you have is further compromised.
fiacra
post May 30 2020, 10:25 AM
Person.Woman.Man.Camera.TV. = MCI
QUOTE(Superhawk996 @ May 30 2020, 07:50 AM) *
All good points, but some miss the point. Many pathogens, such as SARS CoV-2, are primarily spread in aerosolized droplets, which are much larger than the pathogen itself. A mask will provide some protection against those. I can get out of my car and walk through a standard sized residential doorway, but I can't drive my car through the doorway. A good fit is important to improve efficacy of a mask. Facial hair will affect the fit, as will the profile of the nose and face. I am required to be fit tested on a regular basis for an N95 before I can see my patients in the hospital, but even without that level of testing you can get an acceptable fit if you get a good seal. A moldable nose clip is important to help get the best fit possible. I think we also all know by now that a mask will also help prevent an infected person from spreading aerosolized pathogens, which perhaps is their most important function. Moldable nose clip or not, a mask and many other types of facial covering can be helpful to keep us all as safe as possible. Nothing protects 100%, or perhaps even 95%, but anything we can do to help keep us all safer is a step in the right direction. My thanks to Mark and others for coming up with creative ways to make facial coverings.
post May 30 2020, 10:37 AM
Resident German
QUOTE(fiacra @ May 30 2020, 09:25 AM) *
Mikey914   Masks /covers IN PLAID and hound's tooth $10   May 29 2020, 06:13 PM
Mikey914   The N95 version in black and white Hound's too...   May 29 2020, 06:14 PM
sb914   RE: Masks /covers IN PLAID and hound's tooth $10   May 29 2020, 06:35 PM
Larmo63   Not a mask guy. :bullshit:   May 29 2020, 06:41 PM
preach   Not a mask guy. :bullshit: Don't start ...   May 29 2020, 06:54 PM
stevend914   ... to east bumfuck Maine. Big difference. When ...   May 29 2020, 07:05 PM
914e   ... to east bumfuck Maine. Big difference. When...   May 30 2020, 06:44 PM
SirAndy   Not a mask guy. :bullshit: Here we go again ......   May 29 2020, 07:53 PM
bobboinski   PM sent.   May 29 2020, 07:19 PM
Larmo63   Not a mask guy. :bullshit: Here we go again .....   May 29 2020, 07:59 PM
PanelBilly   See my PM   May 29 2020, 09:20 PM
mgp4591   Any other options such as the psychedelic black an...   May 29 2020, 09:40 PM
flat4guy   Those are great.   May 29 2020, 10:13 PM
Andyrew   4 please! Orange, and Black plaid, red hounds...   May 29 2020, 10:39 PM
warpig   :Qarl: Finally the silver lining in the apocalypse...   May 29 2020, 10:51 PM
abes914   I like it. Is it hard to breadth when using it?...   May 29 2020, 11:11 PM
Mikey914   Material is surprisingly easy to breath through fo...   May 30 2020, 01:06 AM
abes914   Material is surprisingly easy to breath through f...   May 30 2020, 01:24 AM
914four   Getting tired of wearing the disposable masks all ...   May 30 2020, 08:24 AM
Superhawk996   I'm game for GB of plague doctor masks with N9...   May 30 2020, 08:24 AM
jeffdon   Are you sewing in a piece of wire over the nose br...   May 30 2020, 08:40 AM
Superhawk996   Are you sewing in a piece of wire over the nose b...   May 30 2020, 08:50 AM
fiacra   Are you sewing in a piece of wire over the nose ...   May 30 2020, 10:25 AM
SirAndy   Many pathogens, such as SARS CoV-2, are primarily ...   May 30 2020, 10:37 AM
Superhawk996   All good points, but some miss the point. . . ...   May 30 2020, 11:36 AM
fiacra   All good points, but some miss the point. . ....   May 30 2020, 12:03 PM
Superhawk996   I think you know I meant anything REASONABLE to ...   May 30 2020, 12:24 PM
SirAndy   5) Force all known HIV positive patients to wear a...   May 30 2020, 12:43 PM
Superhawk996   What is it with you Americans and your obsession...   May 30 2020, 01:44 PM
SirAndy   When you no longer have the right to determine wha...   May 30 2020, 01:53 PM
Superhawk996   When you no longer have the right to determine wh...   May 30 2020, 01:55 PM
914four   Are you sewing in a piece of wire over the nose ...   May 31 2020, 09:57 AM
Mikey914   Are you sewing in a piece of wire over the nose b...   May 30 2020, 11:57 AM
gandalf_025   Regardless of anything else.. Fitted around the no...   May 30 2020, 11:33 AM
johnlush   In for a couple plaid as it has been theorized tha...   May 30 2020, 11:53 AM
rhodyguy   <_< :rolleyes: no good deed goes unpunished...   May 30 2020, 12:20 PM
Andyrew   @[url=http://www.914world.com/bbs2/index.php?showu...   May 30 2020, 01:52 PM
Superhawk996   @[url=http://www.914world.com/bbs2/index.php?show...   May 30 2020, 01:59 PM
jeffdon   You do know what asymptomatic means, right?   May 31 2020, 08:52 AM
ben*james   In for 5. Not because I need them so much but out...   May 30 2020, 03:56 PM
silverg   I would like:1 N95 Black & White, 1 PM2.5 Blac...   May 30 2020, 07:29 PM
DRPHIL914   i am in for a few things , 2 plaid , a black/white...   May 30 2020, 08:11 PM
Morph914   One PM 2.5 cover in Matisse blue tartan and 2 of t...   May 30 2020, 08:16 PM
djway   Physics informs that all things in nature follow t...   May 30 2020, 09:55 PM
KELTY360   Ok, One of the things I've been working on ar...   May 30 2020, 11:00 PM
MartyYeoman   I'd be in for 2ea. of the N95 version in black...   May 30 2020, 11:20 PM
djway   #45 #80 For 2.5   May 31 2020, 12:25 AM
BPic   @mikey914 These are fantastic thank you! I...   May 31 2020, 06:57 AM
Larmo63   In SoCal, wearing a mask is nothing more than virt...   May 31 2020, 03:43 PM
SirAndy   In SoCal, wearing a mask is nothing more than virt...   May 31 2020, 05:05 PM
Superhawk996   In SoCal, wearing a mask is nothing more than vir...   May 31 2020, 05:25 PM
SirAndy   I don't think your beef over the holocaust was...   May 31 2020, 05:44 PM
Rusty   This thread is another political hot potato that w...   May 31 2020, 07:37 PM
KELTY360   This thread is another political hot potato that ...   May 31 2020, 07:58 PM
Mikey914   I'm not down for the politics of the situation...   May 31 2020, 09:43 PM
Larmo63   I said nothing about the holocaust. I live at the...   May 31 2020, 10:12 PM
SirAndy   I said nothing about the holocaust. I live at the...   Jun 1 2020, 10:42 AM
rhodyguy   The roof is on fire....   Jun 1 2020, 08:31 AM
mbseto   ... The point is that life is inherently dangerou...   Jun 1 2020, 08:48 AM
Literati914   :bullshit: .   Jun 1 2020, 10:46 AM
Andyrew   @Mikey914 Mark, I edited my quantities, co wor...   Jun 1 2020, 11:43 AM
Optimusglen   I'd be down for a black/grey plaid one if avai...   Jun 1 2020, 11:59 AM
eric9144   I'd be in for 2 -PM2.5 covers in plaid 80 and ...   Jun 1 2020, 02:25 PM
dlkawashima   Hi Mark, I’m in for a 2.5 houndstooth in orang...   Jun 3 2020, 11:36 PM
RiqueMar   My Grandfather died of COVID-19 3-weeks ago. My Mo...   Jun 4 2020, 12:12 AM
914e   Asking my daughters few days ago which they wanted...   Jun 4 2020, 12:22 AM
Mikey914   Ok, I've got the masks going for those so far....   Jun 4 2020, 12:59 AM
euro911   Mark ... (1) PM2.5 B&W Houndstooth cover (1) ...   Jun 4 2020, 01:03 AM
Mikey914   Mark ... (1) PM2.5 B&W Houndstooth cover (1)...   Jun 4 2020, 01:15 AM
Front yard mechanic   Let me end this thread Plaid is for sissys   Jun 4 2020, 07:12 AM
ClayPerrine   I have not been following this thread but I guess...   Jun 4 2020, 07:35 AM
ClayPerrine   For all of you that were attempting to purchase ma...   Jun 4 2020, 08:57 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:42 AM
