| FJ1200 |
May 30 2020, 08:28 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
| FJ1200 |
May 31 2020, 06:06 AM
Well, I bit the bullet and dropped the engine/trans. Not bad, 40 minutes to the ground. I should mention it has twin webers which I am sure makes it easier. Found both nuts holding the oil filter flange to the case about two turns loose and the gasket blown out. I feel confident that the new gasket and possibly a drop of blue loctite will fix the oil leak. I also will reseal the oil cooler while I am in there as a matter of course.
Any other recommendations "while I am in there"? Valves are adjusted within the last 500 miles, pushrod tubes are clean and dry. Thanks, Daniel |
FJ1200 Oil leak repair May 30 2020, 08:28 AM
Superhawk996 :wttc:
Wecome to 914's.
Two rules of 914... May 30 2020, 08:43 AM
FJ1200 Thanks, for the response.
I know, there has to be... May 30 2020, 08:55 AM
Superhawk996
I know, there has to b... May 30 2020, 09:11 AM
FJ1200 Just checked the oil pressure switch, dry. As a ma... May 30 2020, 09:31 AM
Superhawk996
With Porsche parts prices what they are this will... May 30 2020, 09:44 AM
FJ1200 Thanks,
I have not done a 901, but I have done Au... May 30 2020, 09:54 AM
Superhawk996
Thanks,
I have not done a 901, but I have done A... May 30 2020, 10:05 AM
North Coast Jim Buy the Harbor Freight hydraulic lift table. The 8... May 30 2020, 10:07 AM
Bleyseng :ttiwwp: May 30 2020, 10:19 AM
FJ1200 Thanks for the input guys, money is a little tight... May 30 2020, 10:19 AM
FJ1200 All right, I am going to attempt to post a picture... May 30 2020, 12:12 PM
ndfrigi
All right, I am going to attempt to post a pictur... May 30 2020, 01:08 PM
Superhawk996 :cheer:
:trophy: May 31 2020, 07:47 AM
FJ1200 Miracle of all miracles, all of the oil stays in t... Jun 2 2020, 05:33 PM
Morrie Rather than create a new thread, I am going to jum... Feb 8 2023, 08:14 PM
Dave_Darling There's at least a decent chance that much of ... Feb 8 2023, 09:00 PM
Superhawk996
Hopefully that's not a crack I see where the... Feb 9 2023, 09:10 AM
Morrie
Hopefully that's not a crack I see where th... Feb 9 2023, 02:12 PM
Geezer914 Nice! Love the color. With a 914 that's ... Feb 9 2023, 06:55 AM
Superhawk996 Someone else just went through a similar leak with... Feb 9 2023, 09:06 AM
Morrie
Someone else just went through a similar leak wit... Feb 9 2023, 02:19 PM
bkrantz
Someone else just went through a similar leak wi... Feb 9 2023, 08:33 PM
Superhawk996
That was me.
I didn’t want to rat on you ... Feb 9 2023, 09:00 PM
bkrantz
That was me.
I didn’t want to rat on you ... Feb 10 2023, 08:28 PM
Superhawk996 Oil pressure relief valve has no bearing on the oi... Feb 9 2023, 02:33 PM
Morrie
Oil pressure relief valve has no bearing on the o... Feb 9 2023, 07:58 PM
930cabman I was chasing an oil leak at the front end and fou... Feb 10 2023, 07:21 PM
Superhawk996
I was chasing an oil leak at the front end and fo... Feb 10 2023, 08:24 PM
930cabman
[quote name='930cabman' post='3057145' date='Feb ... Feb 11 2023, 07:56 AM
Superhawk996
[quote name='930cabman' post='3057145' date='Feb... Feb 11 2023, 08:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 12:33 AM |
