> I need help with rear trunk torsion bar, How do I get the bar behind the roller?
Doug Leggins
post Oct 4 2005, 08:55 PM
The teener kicked my ass tonight! I simply wore myself out trying to get the rear trunk torsion bar behind the trunk roller.
I searched for as much info as I cold find before beginning this task. I modified my 12" adjustable wrench as mentioned on other threads on this topic. This tool proved to be a very good lever for pushing the torsion bar back. I could get the torsion bar pushed/twisted back well enough but I could not get it around the hinge roller/pin. I tried several times but could not find a way to get the roller behind the pin on the hinge.
I tried to remove the hinge then hold the torsion bar back as far as I could and then reinstall the hinge -This is the task the wore me out! No matter how or what I tried I could not find a way to get the bar behind the roller.
Anyone know the secret/technique to get the torsion bar in place?
Here is a pic of the wrench with a notch cut out on the end.
BeatNavy
post May 31 2020, 06:05 PM
It can be done with trunk on the hinges. Be careful, and it is very advisable to have a helper (one to hold the rod, one to slip the rollers on). Be careful (IMG:style_emoticons/default/smile.gif)
Doug Leggins   I need help with rear trunk torsion bar   Oct 4 2005, 08:55 PM
Doug Leggins   Trying to bet the black torsion bar behind the bra...   Oct 4 2005, 09:03 PM
Rand   Taking mine OUT was a careful process... putting o...   Oct 4 2005, 09:07 PM
Joe Sharp   Doug: I take my 1/4 screw driver extention and a d...   Oct 4 2005, 10:06 PM
Air_Cooled_Nut   Though I can't help, this topic is perfect bec...   Oct 4 2005, 10:19 PM
olav   To get that puppy on you need to: Preload torsion...   Oct 4 2005, 10:51 PM
Doug Leggins   I thought about the shock kits, even had it on the...   Oct 4 2005, 10:53 PM
olav   There's a "special" tool to do this with and t...   Oct 4 2005, 10:59 PM
Doug Leggins     Oct 4 2005, 11:08 PM
hmeeder   I used this method once upon a time when my hinge ...   Oct 4 2005, 11:14 PM
plas76targa   Doug, To replace a broken plastic roller with an ...   Oct 5 2005, 06:00 AM
ClayPerrine   As was said previously, use a box end wrench to mo...   Oct 5 2005, 08:50 AM
aircooledboy   I have had to do this 3 times to repair my pivot h...   Oct 5 2005, 10:58 AM
flesburg   Guys !!!!!!!!...   Oct 5 2005, 02:52 PM
ClayPerrine   Dale, The cresent wrench modification mentioned ...   Oct 5 2005, 03:46 PM
Joe Sharp   Doug: I takt the 5/16th deep well and slip it on a...   Oct 5 2005, 04:20 PM
Headrage   Excellent solution Joe.   Oct 5 2005, 05:10 PM
Joe Sharp   Thanks Allan. But its not mine, I read it on the b...   Oct 5 2005, 06:19 PM
jsteele22   Car looks sweet, BTW (I'm thinking of convert...   Oct 5 2005, 06:42 PM
Doug Leggins   SUCCESS!!!! http:/...   Oct 5 2005, 08:30 PM
Doug Leggins   transitioning from the 1/4" extension to the notch...   Oct 5 2005, 08:32 PM
Doug Leggins   Using the notched wrench to push the torsion bar f...   Oct 5 2005, 08:36 PM
Doug Leggins   Reaching in from the engine bay with a large screw...   Oct 5 2005, 08:37 PM
Doug Leggins   Screwdriver used to pry the bar around the end of ...   Oct 5 2005, 08:40 PM
Doug Leggins   Torsion bar on the back side of the roller pin...   Oct 5 2005, 08:41 PM
Doug Leggins   Slipped the roller on the pin, cautiously eased up...   Oct 5 2005, 08:45 PM
Lou W   This belongs in the Classic Thread Section. http://www.914world.com/b...   Oct 5 2005, 09:01 PM
jsteele22   Wow, is there anything in your car that isn't ...   Oct 5 2005, 09:20 PM
seanery   ...   Oct 6 2005, 12:07 AM
ClayPerrine   This is a nice picture representation of the proce...   Oct 6 2005, 10:10 AM
Mikey914   No need to make the tool, this looks like the tech...   Nov 28 2017, 12:05 PM
JOEPROPER   :bump: Just bumping this thread because it's r...   Apr 14 2020, 07:46 AM
JOEPROPER   This helped. ALOT. 5 minutes or less with no hel...   Apr 14 2020, 08:05 AM
AZBanks   Great thread. I am going to need it because I have...   Apr 14 2020, 09:10 AM
JOEPROPER   Great thread. I am going to need it because I hav...   Apr 14 2020, 10:16 AM
Jakester1   DOUG, thank you for the great pic's of install...   May 5 2020, 09:44 AM
dt4   tomorrows job is it done with the trunk lid on the...   May 31 2020, 01:51 PM
IronHillRestorations   tomorrows job is it done with the trunk lid on th...   May 31 2020, 04:20 PM
rhodyguy   Prop the trunk fully, FULLY, open for a lid on rol...   Jun 1 2020, 09:17 AM
dt4   defeated me today, it took plenty of effort just t...   Jun 1 2020, 11:27 AM
Mikey914   We just brought on McMark's tool for doing the...   Jun 1 2020, 11:55 AM
Arno914   Place some thick cushioning on the area where the ...   Aug 27 2020, 06:25 AM
Garland   Great tool, glad these are still available, got mi...   Sep 13 2020, 02:33 PM
Mikey914   Link https://914rubber.com/rear-trunk-spring-pre....   Sep 13 2020, 06:02 PM
jrmdir   Older thread but Doug still deserves kudos for the...   Aug 10 2021, 08:57 AM
NARP74   Older thread but Doug still deserves kudos for th...   Aug 10 2021, 09:58 AM
ClayPerrine   How did you determine the location of the JWest b...   Aug 10 2021, 01:21 PM
tomh   I notched an old flat crow bar It worked great.   Aug 10 2021, 09:43 AM
jrmdir   How did you determine the location of the JWest b...   Aug 10 2021, 11:19 AM
jrmdir   Success! I've owned this car for over 2 m...   Aug 10 2021, 02:32 PM
- Lo-Fi Version Time is now: 29th May 2024 - 05:16 AM
