LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
gereed75 |
Jun 4 2020, 09:49 PM
Senior Member Group: Members Posts: 1,250 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Resurrecting an older thread here to add a bit more info to close the loop for six guys.
According to my 70 914-6 wiring diagrams, the two white/blu wires are connected together at the fuse terminal 1. One goes to the instrument lights and one to the headlight relay. I will be doing the grounding of the relay wht/blu tomorrow and hopefully cure my wonky fog/LED headlight thing Incidentally I have three different 914-6 wiring diagrams - the Zapf diagram, a German diagram of unknown origin, and a German diagram I always thought was out of the factory manual. Each has it own individual characteristics/ uses. The two German ones show what we know as fogs to be called “additional high beams” . They show no fog light switch at all. I suspect they are activated via the headlight relay. The factory diagram is easiest to use for tracing colors (very clear color labeling). The other German one has no color labels but does show each switch or connector terminal number. The Zapf calls the second set of lights “fogs” and shows a switch. The Zapf is very difficult to trace wires on in some places, they all blend together. I have found at least one wire color to be wrong. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:09 PM |
