Interesting 1974 Porsche 914 in SoCal (mine) |
Tdskip |
Jun 12 2020, 03:59 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
My car - listing is here. I've shared some details and asked questions about the car here.
https://orangecounty.craigslist.org/cto/d/o...7140719254.html Background: Hello. Up for sale is an interesting 1974 Porsche 914. The car runs and drives, electrical system works and shifts well into all 5 gears and reverse. As you can see from the pictures it is current set up as a race car but could easily be used on the road. The car has a clean AZ title and I have a copy of the clean CA title from the prior owner (who bought it, put it in storage and registered it in AZ because it was cheaper but only owned it for several months). From what I have pieced together from the documentation this was an inland San Diego car and later on Orange County car that was stored when not being raced in Santa Ana. The car sat for several years after the original owners passing away, I did an oil change, and serviced the carbs, got fresh fuel in her and the engine fired right up. She has good cold oil pressure and sounds healthy. The car was apparently used for time attack and auto crossing events. Original engine has been removed, running a 2 L unmarked case, it is currently running a blank case 2 L engine. There is a very trick electric fan oil cooler and it has the deeper tuna can sump set up. I believe the car had a 1.8l engine originally. Body wise she is a very-very solid car. The longs are good, front and rear trunk are rust free, floors are original and undercoating has been removed so you can see factory metal. Battery tray present and in good condition. Looks like the passenger side rear jack point has been replaced. At some point the car had a front end tap. It is hard to see in the pictures but there is some wayness to the inner front fenders. It drives straight and nothing weird going on with the alignment to compensate, and it was used for competition events so I don’t believe there’s any reason it cannot be used as-is for street or track use. As you may have noticed the current body work is a vintage fiberglass wide body kit. Wide as in “holy cow that is wide!” body kit. The car comes with 8 vintage extremely light rims and bias ply slicks and wheel spacers. The tires are OK to roll the car around but don’t hold air very well. The car has a through the body front sway bar and at some point was running a rear bar. From the documentation I pieced together the front torsion bars are now 22mm hollow torsion bars, has uprated shocks as well. The car has an interesting braking set up that is consistent with competition set up. It has normal 914 brake calipers upfront, an in the cockpit front/rear brake proportioning valve, and what looked to be 914 front brakes on the rear for additional stopping power. 5 lug front and rear set up with studs on what I believe are 914 rotors. Electrical system is intact and I believe everything works. Headlights go up and down as they should. Rear lights turn on properly. Comes with what looked to be barely used Simpson driver and passenger racing harness. Car will come with a pair of 914 seats in driver condition. Odometer shows under 11,000 miles (no idea if original), dashboard looks awfully good as does the rest of the dash. Targa top fits properly, in OK but not pristine condition. Currently the car is running a dual carb set up with Dellortto carburetors with a crossbar linkage and fuel pressure regulator and fuel accumulator. The car has a sideshifter which feels good, shifts properly and has all five gears and reverse. This is a great candidate to turn into a serious track/race car, use for autocrossing or could be returned to street use very easily. I can help source replacement OEM fenders if someone wants to go back to street use. Only selling to help fund other Porsche projects. |
pete000 |
Jun 12 2020, 11:11 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Wish I had more space, looks like a great deal for a fun car project that drives already !
Lo-Fi Version | Time is now: 2nd June 2024 - 10:34 AM |
