> Turn Signal Cancel Tab and Horn Failures
The Double S
post Jun 14 2020, 12:45 PM
Hi All,
I have a 1970 914 with an aftermarket Dino steering wheel. I've had issues with the turn signal cancel and the horn not working since I purchased the car.
When I removed the steering wheel and adapter to investigate, it seems like the cancel tab is not long enough to fully initiate the cancel mechanism in the turn signal. It feels like it just touches it half way but still leaves the turn signal on. Is this a result of the tab on the cancel ring being worn out? Or is it the steering wheel adapter fitment preventing the tab to go as far as it needs to?
Additionally, my horn doesn't work. I attached a picture below. It looks like the brass colored arm has been removed or sheered of. Will that affect the performance of the canceling tab?
Thank you for the help in advance.
dr914@autoatlanta.com
post Jun 15 2020, 08:57 AM
your pic is of a 75 76 model with the horn contact tab broken off
QUOTE(The Double S @ Jun 14 2020, 11:45 AM) *
Hi All,
The Double S   Turn Signal Cancel Tab and Horn Failures   Jun 14 2020, 12:45 PM
914Sixer   Early cars are SPECIAL. You might be able to get ...   Jun 14 2020, 01:16 PM
porschetub   Early cars are SPECIAL. You might be able to get...   Jun 14 2020, 04:29 PM
The Double S   Early cars are SPECIAL. You might be able to ge...   Jun 14 2020, 11:16 PM
porschetub   Hi All, I have a 1970 914 with an aftermarket Di...   Jun 14 2020, 04:21 PM
The Double S   I don't know what adapter I have. The car c...   Jun 14 2020, 11:06 PM
dr914@autoatlanta.com   your pic is of a 75 76 model with the horn contact...   Jun 15 2020, 08:57 AM
The Double S   Is there a ring available with a longer tab?   Jun 16 2020, 12:53 AM
ClayPerrine   Is there a ring available with a longer tab? A...   Jun 16 2020, 06:48 AM
The Double S   Sorry, I wasn't clear. I meant a longer tab on...   Jun 16 2020, 09:27 AM
The Double S   Example of what I am talking about below. Perhaps...   Jun 17 2020, 05:48 PM
The Double S   Anyone have experience in this area with steering ...   Jun 23 2020, 02:51 PM
914sgofast2   I had to put some flat washers under the turn sign...   Jun 23 2020, 07:39 PM
The Double S   Thanks gofast2. I had the same idea with the washe...   Jun 23 2020, 08:15 PM
PCH   Could you point out in the picture where you put t...   Jun 24 2020, 01:36 PM
The Double S   Could you point out in the picture where you put ...   Jun 24 2020, 08:41 PM
PCH   Thank you for the close-up and your help. I'm ...   Jun 25 2020, 05:44 PM
The Double S   Update: I put 3 flat washers on each screw that mo...   Jun 27 2020, 10:22 PM
- Lo-Fi Version Time is now: 25th April 2026 - 04:53 PM
