Rear Mount Oil Cooler Planning, Ok, leaking oil again... |
BeatNavy |
May 31 2020, 06:45 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
With the addition of my 2270 I'm now pushing oil temps toward 230 on an 80 degree day. I am not surprised, but wanted to run it for a bit just to make sure an external oil cooler is truly necessary.
I think it is truly necessary. I've researched and planned this some, but I'm still looking for sanity check, comments, and answers where appropriate. You'll notice I'm trying to stick with Setrab for most of this under the assumption that the pieces should work together. 1. This will be rear-mount cooler: Setrab Series 1 19-row w/Fan. It looks compact, has the fan, and was recommended to me. It will be mounted somewhere under trunk / over gearbox, probably passenger side. 2. Sandwich plate adapter. I've considered going with CFR's system, but I'll probably stick with the sandwich plate route at this point. Which sandwich plate? I assume it needs to be low-profile to avoid interference with cross-bar, but these things run from $26 to over $200 depending, I guess, whether or not they have thermostat. I was thinking of going with this one: 3/4 x 16 1-inch Sandwich Plate 3. Oil line fittings. I guess I need 2 for the sandwich adapter plate and 2 for the cooler itself. From a planning standpoint should I assume straight, 45 or 90 degree angled, particularly for clearance purposes off the adapter? 4. Oil lines. Going with steel braided, and I was thinking about 10 feet of AN8. Any advantage/disadvantage to AN8 versus AN10?. I'm going to get the Koul Tool oil line tool to help fabricate these. 5. Thermostat fan switch - was planning on the Setrab 190 degree thermostat switch. 6. Then I guess I need to go fused or relay on the power. Need to research that a bit more. 7. Am I missing anything or any other gotchas before I start ordering stuff? As always, thanks for advice and help. Adding an external cooler obviously makes everything a bit more complex and crowded underneath. I guess I should have stuck with the original 1.7L I had years ago. NOT! (IMG:style_emoticons/default/happy11.gif) |
Craigers17 |
Jun 18 2020, 04:42 PM
Senior Member Group: Members Posts: 744 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Nice looking setup! Looking forward to hearing what type of numbers you end up with. I also wondered if you have any pics of the business end of that heat tubing ? In other words, what type of duct are you using and where do you have it located? Looks great!
Lo-Fi Version | Time is now: 8th June 2024 - 10:05 AM |
