Rear Mount Oil Cooler Planning, Ok, leaking oil again... |
BeatNavy |
May 31 2020, 06:45 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
With the addition of my 2270 I'm now pushing oil temps toward 230 on an 80 degree day. I am not surprised, but wanted to run it for a bit just to make sure an external oil cooler is truly necessary.
I think it is truly necessary. I've researched and planned this some, but I'm still looking for sanity check, comments, and answers where appropriate. You'll notice I'm trying to stick with Setrab for most of this under the assumption that the pieces should work together. 1. This will be rear-mount cooler: Setrab Series 1 19-row w/Fan. It looks compact, has the fan, and was recommended to me. It will be mounted somewhere under trunk / over gearbox, probably passenger side. 2. Sandwich plate adapter. I've considered going with CFR's system, but I'll probably stick with the sandwich plate route at this point. Which sandwich plate? I assume it needs to be low-profile to avoid interference with cross-bar, but these things run from $26 to over $200 depending, I guess, whether or not they have thermostat. I was thinking of going with this one: 3/4 x 16 1-inch Sandwich Plate 3. Oil line fittings. I guess I need 2 for the sandwich adapter plate and 2 for the cooler itself. From a planning standpoint should I assume straight, 45 or 90 degree angled, particularly for clearance purposes off the adapter? 4. Oil lines. Going with steel braided, and I was thinking about 10 feet of AN8. Any advantage/disadvantage to AN8 versus AN10?. I'm going to get the Koul Tool oil line tool to help fabricate these. 5. Thermostat fan switch - was planning on the Setrab 190 degree thermostat switch. 6. Then I guess I need to go fused or relay on the power. Need to research that a bit more. 7. Am I missing anything or any other gotchas before I start ordering stuff? As always, thanks for advice and help. Adding an external cooler obviously makes everything a bit more complex and crowded underneath. I guess I should have stuck with the original 1.7L I had years ago. NOT! (IMG:style_emoticons/default/happy11.gif) |
Montreal914 |
Jun 19 2020, 08:01 PM
Senior Member Group: Members Posts: 1,587 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
@GregAmy , great idea to wire it through MS. I will add this to my list. I do wave the thermo switch in an AN fitting that looks like yours. But it has basic spade connectors. I have a feeling you are using a different sensor, coolant temp sensor maybe?
Maybe I should consult your blog, the info might be in there... (IMG:style_emoticons/default/idea.gif) |
GregAmy |
Jun 19 2020, 08:31 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
QUOTE Little things tell a lot about a person's character....like the aircraft grade safety wire install on the CV axle in the background. You sir are a true artisan! lol Thank you but...I just realize in looking at that photo that I wired it backwards...DAAAAMIIITT!!! I'm sure beer was involved. Eh, I guess it does the job. But I'm seriously gonna rewire it tomorrow. I have a feeling you are using a different sensor, coolant temp sensor maybe? I'm using the Race Technology temperature sensor that includes the pull-up resistor if you buy it with the lead. I use R-T products for the race cars... https://www.race-technology.com/us/racing/p...ter-temperature Buy that and you won't have to solder/insert a pull-up resistor on the Microsquirt board. It's just really wire it up and play. The sensor for R-T is about $60, and I bought the -10AN inline port here: http://www.improvedracing.com/an-tee-fitti...port-p-882.html I have the .inc file for the sensor linked in Part 11 here: https://tgadrivel.blogspot.com/2020/06/on-m...-addendums.html Using the Microsquirt is a bit of a rub-your-tummy thing because the MS doesn't recognize the INC file. But you can use the ADC numbers to allow it to control the fan. PM or email me for a more verbose description. You know where to find me... (IMG:style_emoticons/default/wink.gif) - GA |
Lo-Fi Version | Time is now: 8th June 2024 - 07:21 AM |
