Engine barely turns over, need help |
solex |
Jun 20 2020, 10:41 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have done a lot of work and had the car running fine for serveral but now I have an electrical problem that I cannot seem to find.
Symptoms: Starter will turn a few degrees but will not turn over the engine when I release the key the starter will turn over a few more degrees as though I still have the key in the start position. What I checked:
Recent work done (may not be relevant):
Superhawk996 |
Jun 20 2020, 02:00 PM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
0.1 ohm is too high of resistance
Ohms Law voltage = current x resistance Stating can draw several hundred amps Let’s use 100 amps to keep the math easy 100a x 0.1 ohm = 10 volt drop You can see how even a 50a starter current will drop 5 volts across that strap. Not good. |
solex |
Jun 20 2020, 02:21 PM
0.1 ohm is too high of resistance Ohms Law voltage = current x resistance Stating can draw several hundred amps Let’s use 100 amps to keep the math easy 100a x 0.1 ohm = 10 volt drop You can see how even a 50a starter current will drop 5 volts across that strap. Not good. I just checked the specs on my meter and 0.1 is the lower limit of the meter so I would need to get a better meter to confirm the actual resistance of the strap but will order a new one |
Lo-Fi Version | Time is now: 6th June 2024 - 03:18 AM |
