SIX mount question, Patrick Moly Bar |
Trekkor |
Dec 15 2004, 05:51 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Does this mount solid or should I be using rubber mounts like the 911 sport mount on my trans?
Thanks KT |
Britain Smith |
Dec 16 2004, 11:37 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
QUOTE(9146986 @ Dec 15 2004, 07:52 PM) QUOTE(Britain Smith @ Dec 15 2004, 04:40 PM) You should use the WEVO engine mounts. I have some nice SPORT mounts around here somewhere. I respectfully disagree. Solid mounts transmit loads of vibrations. Richard Parr the PMO guy has posted a detailed dissertation in some of his advertising that says it's not a good idea for a engine with carbs. If it was a race car, maybe. The WEVO mounts are not solid mounts. They are semi-solid and just a step above the sport mounts. Here is what is listed on their website... QUOTE The WEVO SS Engine Mount is designed to offer virtually the same locating advantages of a solid engine mount – without the metal to metal contact between the chassis and the engine. The SS Engine Mount comprises of 5 components. The design of the components ensures that at rest, or idle, the engine is firmly located, but free to vibrate against the elastomeric pillows isolating the engine mount inner and outer components. When the engine reacts to torque, the components deflect slightly and the spring rate of the isolators is progressively increased, improving the location of the engine and transmission under more stressful conditions. The design is such that metal to metal contact is always avoided, so potentially harmful misalignment forces and vibrations are managed in a manner more similar to the original factory rubber mounts. The SS Engine Mounts are installed using the original hardware and have a gold anodized finish similar in appearance to the gold zinc plated factory parts. The SS Engine Mount is an upgrade suited to cars used for spirited road driving all the way through full race cars. Testing on road and track cars has shown a significant reduction in vibration transmitted versus solid mounts, without reduction in chassis performance, or gear selection accuracy. Owners of cars with Weber or PMO carburetors will be pleased to know that development of this product was encouraged by Richard Parr at PMO as a way of protecting against carburetor issues related directly to engine vibrations. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:13 AM |
