> Heat Shield Mounting Question
914_7T3
post Jun 23 2020, 11:05 PM
Would like to confirm if the the heat shield above the muffler is bolted into the cross section of the rear trunk from underneath or is it welded in place?
Just learned I don't have one installed and the heat is baking my new paint in the trunk from underneath. Have one sourced already and will also be going with heat insulation matting for extra protection.
aharder
post Jun 24 2020, 11:35 AM
My 75 is welded, I plan on using inserts to re-install once I remove and repair the trunk pan
914_7T3   Heat Shield Mounting Question   Jun 23 2020, 11:05 PM
bdstone914   Would like to confirm if the the heat shield abov...   Jun 24 2020, 04:38 AM
mepstein   Would like to confirm if the the heat shield abo...   Jun 24 2020, 11:56 AM
barefoot   For my 76, it was welded on. Since I replaced a p...   Jun 24 2020, 06:52 AM
aharder   My 75 is welded, I plan on using inserts to re-ins...   Jun 24 2020, 11:35 AM
davep   From what I have seen, all the 914/6 had them fast...   Jun 24 2020, 11:59 AM
SirAndy   From what I have seen, all the 914/6 had them fas...   Jun 25 2020, 12:49 PM
bkrantz   Bolt-in? Weld-in? Why not both? My solution: we...   Jun 24 2020, 08:43 PM
bkrantz   And then bolt on the heat shield.   Jun 24 2020, 08:44 PM
914werke   I like it   Jun 25 2020, 12:26 AM
zoomCat   As it turns out I was looking at this very thing t...   Jun 25 2020, 09:44 AM
FlacaProductions   Maybe instead of the shield - 1 or two of these? ...   Jun 25 2020, 10:42 AM
ElCee   I have a 914/4 from May 1970. My car has a heat sh...   Jun 25 2020, 11:07 AM
Eric_Shea   Not easy to get at but, it can be welded back in. ...   Jun 25 2020, 11:23 AM
zoomCat   Interesting, the much clearer pictures of the /4 s...   Jun 25 2020, 11:24 AM
914_7T3   Thanks for chiming in and the solutions are great....   Jun 25 2020, 11:43 AM
davep   Thanks Andy, I stand corrected. There are so few 7...   Jun 25 2020, 03:33 PM
rgalla9146   The 'screw in' early one is found in both ...   Jun 25 2020, 05:38 PM
cuddy_k   My guess (and it's just a guess) is it might n...   Jun 25 2020, 09:06 PM
Montreal914   Planning on installing my new trunk panel this wee...   Feb 12 2021, 11:06 AM
rgalla9146   Welding a shield in is easy. Mark where the...   Feb 12 2021, 11:29 AM
Montreal914   Sure, but I like the idea of being able to remove ...   Feb 12 2021, 03:15 PM
bkrantz   Just over 1-1/2 inches, from inside the rear body ...   Feb 12 2021, 09:48 PM
Montreal914   Just over 1-1/2 inches, from inside the rear body...   Feb 13 2021, 10:53 AM
rgalla9146   Beautiful.   Feb 12 2021, 10:34 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:13 PM
