| 914_7T3 |
Jun 23 2020, 11:05 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
Would like to confirm if the the heat shield above the muffler is bolted into the cross section of the rear trunk from underneath or is it welded in place?
| bkrantz |
Jun 24 2020, 08:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Bolt-in? Weld-in? Why not both?
My solution: weld in some simple brackets. Attached thumbnail(s) |
914_7T3 Heat Shield Mounting Question Jun 23 2020, 11:05 PM
bdstone914
Would like to confirm if the the heat shield abov... Jun 24 2020, 04:38 AM
Would like to confirm if the the heat shield abo... Jun 24 2020, 11:56 AM
barefoot For my 76, it was welded on. Since I replaced a p... Jun 24 2020, 06:52 AM
aharder My 75 is welded, I plan on using inserts to re-ins... Jun 24 2020, 11:35 AM
davep From what I have seen, all the 914/6 had them fast... Jun 24 2020, 11:59 AM
From what I have seen, all the 914/6 had them fas... Jun 25 2020, 12:49 PM
bkrantz And then bolt on the heat shield. Jun 24 2020, 08:44 PM
914werke I like it Jun 25 2020, 12:26 AM
zoomCat As it turns out I was looking at this very thing t... Jun 25 2020, 09:44 AM
FlacaProductions Maybe instead of the shield - 1 or two of these?
... Jun 25 2020, 10:42 AM
ElCee I have a 914/4 from May 1970.
My car has a heat sh... Jun 25 2020, 11:07 AM
Eric_Shea Not easy to get at but, it can be welded back in.
... Jun 25 2020, 11:23 AM
zoomCat Interesting, the much clearer pictures of the /4 s... Jun 25 2020, 11:24 AM
914_7T3 Thanks for chiming in and the solutions are great.... Jun 25 2020, 11:43 AM
davep Thanks Andy, I stand corrected. There are so few 7... Jun 25 2020, 03:33 PM
rgalla9146 The 'screw in' early one is found in both ... Jun 25 2020, 05:38 PM
cuddy_k My guess (and it's just a guess) is it might n... Jun 25 2020, 09:06 PM
Montreal914 Planning on installing my new trunk panel this wee... Feb 12 2021, 11:06 AM
rgalla9146 Welding a shield in is easy.
Mark where the... Feb 12 2021, 11:29 AM
Montreal914 Sure, but I like the idea of being able to remove ... Feb 12 2021, 03:15 PM
bkrantz Just over 1-1/2 inches, from inside the rear body ... Feb 12 2021, 09:48 PM
Montreal914
Just over 1-1/2 inches, from inside the rear body... Feb 13 2021, 10:53 AM
rgalla9146 Beautiful. Feb 12 2021, 10:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:13 PM |
