BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Found one. Thanks! |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() |
BillC |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? |
JOEPROPER |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. |
BillC |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. @ JOEPROPER PM sent. Thank you very much! |
Lo-Fi Version | Time is now: 16th August 2025 - 02:13 PM |
