| waltonsm |
Jun 12 2020, 11:53 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 27-June 14 From: United States Member No.: 17,561 Region Association: Pacific Northwest
After seeing some recent posts, I decided it was finally time to thank everybody on this forum for years of encouragement and scope creep on my long term project. As with every real project, this will never be done, and there are certainly many things I would do differently a second time around. But I am 80% of the way there, and I am enjoying driving it as much as I am working on it for the last year or so.
I plan to add more photos of my build process over the next few weeks. You may see some of the advice you gave me realized, and probably some bad or good ideas in metal, fiberglass, and wood. Hopefully I can help someone else out too. -Steve Here are some recent photos: And a few from about 4 years ago: |
| waltonsm |
Jun 30 2020, 09:18 PM
Time to add some more photos: Trying to capture mostly what was done (and since modified) for the rear subframe.
Objectives: -make the subframe a rolling cart with adjustable corners for simple motor drops for engine work (proven, unfortunately) -use it to box out the rear end of the car -hang as much off the subframe as possible -get the engine as high and forward as possible, ground clearance and cg In the end I mounted the intercooler, oil cooler, muffler, and rear sway bar on the subframe, of course in addition to the engine and trans. I used Subaru group N engine mounts, I later added the pitch stop off brackets at the rear of trans to manage axial motion to stiffen it a bit. I have enough degrees of freedom to adjust the up-pipe, turbo,downpipe,exhauts tip location. I did end up making a small cut in the rear trunk to fit the turbo, this was an early design error that I just ended up going with (to keep the turbo in stock location). |
waltonsm 914 WRX Build Jun 12 2020, 11:53 PM
waltonsm some milestones:
Jun 12 2020, 11:58 PM
waltonsm some more:
Jun 13 2020, 12:00 AM
waltonsm some more:
Jun 13 2020, 12:02 AM
Thunderchief Super cool! Very clean and professional lookin... Jun 13 2020, 12:18 AM
BIGKAT_83 Nice !!!
All your parts are top of the... Jun 13 2020, 05:51 AM
Cairo94507 Nice work and skills set. Glad you are getting to... Jun 13 2020, 06:20 AM
76-914
Nice work and skills set. Glad you are getting t... Jun 13 2020, 08:54 AM
Retroracer Very cool build - pls keep the posts & pics fl... Jun 13 2020, 02:19 PM
waltonsm
Very cool build - pls keep the posts & pics f... Jun 14 2020, 12:09 AM
PanelBilly I want to go for a ride! Jun 13 2020, 09:44 PM
waltonsm
I see you are in th... Jun 13 2020, 11:42 PM
kroelofsen Envy... :headbanger: Jun 14 2020, 02:42 AM
waltonsm And some more subframe photos, including the mods ... Jun 30 2020, 09:19 PM
Thunderchief What kind of heated seats are you running? Do they... Jul 1 2020, 12:57 AM
waltonsm
What kind of heated seats are you running? Do the... Jul 3 2020, 11:53 AM
Dion Cool build. Looks pretty bad-ass. You’ve put som... Jul 1 2020, 05:05 AM
ClayPerrine This is an absolutely cool build. The workmanship ... Jul 1 2020, 06:27 AM
Chris H. Wow REALLY cool build! Thanks for sharing it.... Jul 1 2020, 09:05 AM
waltonsm
Wow REALLY cool build! Thanks for sharing it... Jul 3 2020, 12:38 PM
DRPHIL914
Super cool! Very clean and professional looki... Jul 1 2020, 09:31 AM
waltonsm
Super cool! Very clean and professional look... Jul 3 2020, 12:51 PM
CBee Yeah! Super fab skills.
I'll be borrowing... Jul 1 2020, 12:10 PM
waltonsm
I'll be borrowin... Jul 3 2020, 12:56 PM
waltonsm Nearly a year has passed since my last updates. Tu... Jun 16 2021, 09:33 PM
waltonsm For a long time I had plans to build the wing. I k... Jun 16 2021, 09:53 PM
waltonsm After a few more months I decided I wanted the win... Jun 16 2021, 10:07 PM
mgarrison Amazing Suby build! Incredible fab skills... :... Jun 17 2021, 09:18 AM
waltonsm
Amazing Suby build! Incredible fab skills... ... Jun 21 2021, 10:07 PM
waltonsm
Amazing Suby build! Incredible fab skills... ... Jun 21 2021, 10:39 PM
AZBanks Amazing build. I'm curious what metalworking t... Jun 17 2021, 09:23 AM
waltonsm
Amazing build. I'm curious what metalworking ... Jun 21 2021, 08:06 PM
ValcoOscar :D :)
:beer2: :beer1: :beer3:
:first:
O N... Jun 17 2021, 09:41 AM
waltonsm Will write up the new turbo swap next.
... Jun 21 2021, 11:10 PM
mgarrison Thanks! Really appreciate all the details and ... Jun 22 2021, 09:05 AM
waltonsm It is time for an update on what I have been up to... Mar 24 2022, 01:58 PM
waltonsm I was pretty certain the issue was with the final ... Mar 24 2022, 02:24 PM
waltonsm The good news is that the engine and transmission ... Mar 24 2022, 02:52 PM
waltonsm While waiting for transmission parts I decided to ... Mar 25 2022, 11:50 PM
waltonsm After the transmission was well under way, I worke... Mar 26 2022, 01:44 AM
waltonsm I decided to make a jig for adding 1.75 deg of cam... Mar 26 2022, 05:14 PM
waltonsm I also needed to raise the shock mounting points a... Mar 26 2022, 06:07 PM
waltonsm I also ended up lowering the front spindles on the... Mar 26 2022, 06:17 PM
tygaboy Absolutely love it. FABricationULOUS! :wub: ... Mar 26 2022, 06:21 PM
waltonsm
Absolutely love it. FABricationULOUS! :wub: ... Mar 26 2022, 06:43 PM
waltonsm And this is where it is right now. I modified and ... Mar 26 2022, 06:23 PM
Mayne Amazing car and a fantastic build! Thanks for ... Mar 27 2022, 07:54 AM
Chris914n6 Can you elaborate on the Boxster parts on the trai... Apr 2 2022, 10:18 AM
waltonsm
Can you elaborate on the Boxster parts on the tra... Apr 9 2022, 02:12 PM
waltonsm Here are the pics of the cable routing and and ear... Apr 9 2022, 02:15 PM
waltonsm I have gotten a few questions about the axles/CVs,... Apr 9 2022, 02:24 PM
East coaster What size are the BFGs? Apr 18 2022, 06:17 AM
waltonsm
Off-road, KO2 are
Front ... Apr 18 2022, 02:30 PM
Root_Werks What a cool build! Apr 18 2022, 04:48 PM
waltonsm Thanks guys. While ruminating over the fact I will... Apr 22 2022, 08:08 AM
DRPHIL914
Thanks guys. While ruminating over the fact I wil... Apr 22 2022, 09:12 AM
waltonsm Made notable progress on my replacement tuning sol... May 4 2022, 12:00 AM
autopro Wow your car is coming out awesome, you really are... May 4 2022, 12:32 AM
pbanders Very impressive, will have to take the time to go ... May 4 2022, 09:12 AM
waltonsm Had a chance to get out and put a couple hundred m... May 8 2022, 07:42 PM
waltonsm Now that it got cold in Seattle, I decided it was ... Dec 21 2022, 08:04 PM
waltonsm Continuing with the control arm extension..
... Dec 21 2022, 08:10 PM
sb914 So bad ass .
Looks perfect in my driveway. :poke: Dec 22 2022, 07:01 AM
ValcoOscar For years I've thought about building a Safari... Dec 22 2022, 08:14 AM
waltonsm
For years I've thought about building a Safar... Dec 22 2022, 11:59 AM
tygaboy This one is my current favorite 914. I'd love ... Dec 22 2022, 09:21 AM
waltonsm
This one is my current favorite 914. I'd love... Dec 22 2022, 12:16 PM
ValcoOscar I happy to inspire some stalled or new projects an... Dec 22 2022, 12:41 PM
Root_Werks Very smart to add the extra metal. Very unique 91... Dec 22 2022, 12:09 PM
RKramden @waltonsm
So impressive! I couldn’t begin t... Dec 22 2022, 10:03 PM
waltonsm
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 23 2022, 12:23 AM
RKramden That would be “thanks”. Dec 22 2022, 10:05 PM
waltonsm Turns out I found some photos from when I finally ... Dec 23 2022, 01:07 AM
RKramden Perfect, thank you so much.
One question, it loo... Dec 23 2022, 08:58 AM
RKramden Sorry, I thought of one other question. I see you... Dec 23 2022, 09:14 AM
waltonsm
Sorry, I thought of one other question. I see yo... Dec 23 2022, 03:59 PM
RKramden Thank you for sharing your knowledge.
Happy Holida... Dec 23 2022, 08:24 PM
waltonsm I have gotten a few questions about the steering c... Jan 1 2023, 08:32 PM
waltonsm I got a few questions on fender install recently, ... Feb 19 2023, 04:32 PM
Root_Werks Had a chance to meet Steve in person and see his 9... Mar 6 2023, 11:53 AM
Gearup Hey Steve. Great project. Was curious where you b... Mar 6 2023, 06:52 PM
waltonsm Hi Brett, took me a bit to remember the right word... Mar 8 2023, 06:31 PM
waltonsm It was great to meet Dan too and check out his fun... Mar 8 2023, 06:36 PM
waltonsm Nice earthy day to come home to the northwest.
Mar 25 2023, 12:40 AM
waltonsm PSA…
Sheared off a diff stub axle this weekend.... Mar 28 2023, 02:05 PM
East coaster Ouch! Mar 29 2023, 04:36 AM
jd74914 Did that shear at a snap ring groove Mar 29 2023, 06:55 AM
waltonsm The fracture occurred at the the small diameter of... Mar 29 2023, 11:13 AM
waltonsm Did the work to swap the stubs this morning. Start... Apr 8 2023, 08:12 PM
Root_Werks Nicely done! I was trying to picture the shee... Apr 10 2023, 02:51 PM
waltonsm And back on the ground.. with wider front track. A... Mar 17 2024, 07:55 PM
sb914
And back on the ground.. with wider front track. ... Mar 18 2024, 06:26 AM
DRPHIL914 Looking good!!
:headbanger: Mar 18 2024, 06:25 AM
East coaster What goes up must come down…….are you planning... Mar 19 2024, 05:21 AM
waltonsm Absolutely will lift it again. It was super fun wi... Mar 22 2024, 11:53 PM
waltonsm Had some recent inspiration while cleaning the gar... Sep 26 2024, 06:14 PM
Root_Werks Getting to a point you can work on some of the sma... Sep 27 2024, 10:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 02:37 AM |
