WTB: 74 1.8 AAR rubber elbow |
CoronaMike |
Jul 6 2020, 06:31 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
Mikey914 |
Jul 7 2020, 01:47 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We do ,
Thanks Cary |
CoronaMike |
Jul 7 2020, 08:39 AM
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) |
JamesM |
Jul 7 2020, 11:30 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) What is the hose ID on the one that came out? The elbows I received from 914 rubber fit both the early and late AARs that i have around here (along with most other hose connections on my 2.0s and 1.7s. They do have to stretch a bit to make the connection but that is necessary as it needs to be an air tight seal. Per the 1.8 hose diagram that i have all those hoses from the AAR on a 1.8 should be 13mm(which these fit) only hose I see that is larger on the 1.8 is from the Decel Valve. Are you sure your hose routing is correct? |
Lo-Fi Version | Time is now: 6th June 2024 - 11:46 PM |
