Transaxle Reseal Dilemma, Need Advice! |
Ansbacher |
Jul 8 2020, 11:43 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
My '74 2.0 leaks transaxle gear oil, so I want to pull the transmission (JUST THE TRANSMISSION) and redo all the seals. Having a very small garage, I must remove the tranny in my driveway, then put the car back in the garage while I do the seals at my leisure. Question: can I push the car back into the garage with dangling axles; what do I do with them, support them somehow? Also, is there a way to support the weight of the engine while I roll the car back into the garage? Trying to avoid leaving the car out in the elements while I do this job, as I have never done seals before and don't know how long its going to take me if I run into problems. Need advice badly. Thanks.
Ansbacher |
brant |
Jul 8 2020, 12:50 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
is your clutch wet when you look in the window on the top of the bell housing?
do you know where your leaking at? the front main, requires pulling the trans but the side output shaft seals and rear speedo drive seal can be addressed with the trans in the car.... a lot less work than pulling everything but then again, that front main seal there is no easy way around it. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:50 AM |
