Transaxle Reseal Dilemma, Need Advice! |
Ansbacher |
Jul 8 2020, 11:43 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
My '74 2.0 leaks transaxle gear oil, so I want to pull the transmission (JUST THE TRANSMISSION) and redo all the seals. Having a very small garage, I must remove the tranny in my driveway, then put the car back in the garage while I do the seals at my leisure. Question: can I push the car back into the garage with dangling axles; what do I do with them, support them somehow? Also, is there a way to support the weight of the engine while I roll the car back into the garage? Trying to avoid leaving the car out in the elements while I do this job, as I have never done seals before and don't know how long its going to take me if I run into problems. Need advice badly. Thanks.
Ansbacher |
TheCabinetmaker |
Jul 8 2020, 03:02 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Jonathan said it right! The rear of the engine must be supported or you will rip the motor mounts, and bend the pick up points on the ends of the mount bar. If your going to move the car, pull the whole drive train, then seperate the two. Then you can clean the engine and engine bay too. Axles can hang when rolling, new problem.
KELTY360 |
Jul 8 2020, 10:19 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Jonathan said it right! The rear of the engine must be supported or you will rip the motor mounts, and bend the pick up points on the ends of the mount bar. If your going to move the car, pull the whole drive train, then seperate the two. Then you can clean the engine and engine bay too. Axles can hang when rolling, new problem. (IMG:style_emoticons/default/agree.gif) I did this once and found that it was as much work, if not more to pull just the tranny as opposed to the whole engine. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:06 PM |
