Alloy Lug Nuts, How do you strip Off the black ? |
jim_hoyland |
Jul 9 2020, 03:43 PM
Get that VIN ? Group: Members Posts: 9,320 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What’s the trick to get the black finish completely off ?
Attached image(s) |
jim_hoyland |
Jul 9 2020, 07:53 PM
HF $30.00 ? Would this do the trick
Requires a 1 HP compressor per their ad Attached image(s) |
mepstein |
Jul 9 2020, 09:44 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
HF $30.00 ? Would this do the trick Requires a 1 HP compressor per their ad That is a costly, messy way to remove some anodizing by the time you buy blast media.. What are you going to do once the black is gone. If you are going to powdercoat, the powder company will blast. If you are going to anodize, the anodizing company will remove the black and recoat. If you are going to paint, just scuff but paint doesn't last unless its epoxy or cerikote. If you are going to polish, don't bead blast, it will leave it rough and require a ton of sanding. If you are going to polish, you will need to anodize clear or it will cloud over. Might be cheaper just to buy new. What's the goal here? |
Lo-Fi Version | Time is now: 11th June 2024 - 03:56 AM |
