'70 vrs '71 wiring differences, Headlight switch, circuits and wiring |
IronHillRestorations |
Jul 15 2020, 04:53 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm doing a chassis harness replacement on a '71 4 cyl car. Not exactly sure what happened but there was some melted wires to the headlight motors.
I found a good salvage harness, and in the process of doing the swap. I've found a discrepancy between the wiring for the headlight switch. The replacement harness does not have a gray wire that was in the original harness, and did not include the switch. The gray wire in the original harness goes to terminal #56 on the headlight switch and to terminal "K" for the headlight motors. Doing more tracing today, but part of the problem is melted wires. The factory manuals do not show a wiring schematic for all years, so I can't compare the two. Anyone know the differences? I know there are different harnesses for each year model, except '76. I think the headlight switch is the same for '70 and '71 Any thoughts on this? @JeffBowlsby @ClayPerrine @raynekat @Spoke @BDStone914 |
JeffBowlsby |
Jul 15 2020, 09:07 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is the switch circuitry diagram, if it helps:
https://bowlsby.net/914/WiringHarnesses/DashSwitches.pdf |
Lo-Fi Version | Time is now: 1st June 2024 - 10:00 AM |
