| Coondog |
Jul 28 2020, 10:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California
| Steve |
Jul 29 2020, 06:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,127 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....??
This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit. |
| 76-914 |
Jul 29 2020, 10:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....?? This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit. 40 amps is on low or the lowest scroll rpm. Medium is 60a and high is 96a IIRC. Not that it won’t work and I hope it does. Lots of people need AC in their 914’s. I like the look of the evaporator Keith selected. As I told Keith, hose routing is very tight under the dash. I needed to flatten mine down to get past the steering column. (IMG:style_emoticons/default/beerchug.gif) |
Coondog Elec Air Cond Jul 28 2020, 10:32 PM
eric9144 That's pretty slick, did that go into the blue... Jul 28 2020, 11:30 PM
Coondog
That's pretty slick, did that go into the blu... Jul 29 2020, 07:08 AM
Matty900
That's pretty slick, did that go into the bl... Jul 29 2020, 10:41 AM
Cairo94507 Hi Greg, I am watching for this too. I would love... Jul 29 2020, 06:20 AM
JmuRiz eeeeeexcellent Guess I should get a high power al... Jul 29 2020, 10:59 AM
mepstein They are great units but when you tell people they... Jul 29 2020, 11:28 AM
IronHillRestorations You've got to have a very high output alternat... Jul 29 2020, 11:28 AM
You've got to have a very high output alterna... Jul 29 2020, 11:29 AM
Cairo94507 Me- Long pause....... :beer2: Jul 29 2020, 11:29 AM
nditiz1 For any one with a 911 there is a group buy schedu... Jul 29 2020, 12:54 PM
RFoulds If its the same system that is currently available... Jul 29 2020, 02:49 PM
If its the same system that is currently availabl... Jul 29 2020, 03:03 PM
76-914 Someone here is doing an elec AC in his 6. It will... Jul 29 2020, 03:16 PM
GregAmy Heat doesn't work well in winter, A/C is too e... Jul 29 2020, 03:49 PM
rgalla9146 Many are interested in this.
I wish there wer... Jul 29 2020, 05:31 PM
Jonny Retrofit
Keith and I are playing around with different opt... Aug 1 2020, 04:26 PM
76-914
Keith and I are playing around with different op... Aug 2 2020, 12:44 PM
Jonny Retrofit
Our system does not rely on 'ram air' fo... Aug 3 2020, 06:15 AM
Steve
Our system does not rely on 'ram air' f... Aug 3 2020, 07:07 AM
914forme 96a just means you will be hitting the backup stor... Jul 30 2020, 07:10 AM
76-914
96a just means you will be hitting the backup sto... Jul 30 2020, 08:37 AM
914Toy I will be collecting pics along this technical jou... Jul 30 2020, 08:30 AM
Luke M :popcorn:
I need a/c in my 6 too. I'll be ke... Jul 30 2020, 08:49 AM
Bleyseng For a 4 cylinder then sourcing a 70amp bus alterna... Jul 30 2020, 09:26 AM
Steve
For a 4 cylinder then sourcing a 70amp bus altern... Jul 30 2020, 10:36 AM
914e
For a 4 cylinder then sourcing a 70amp bus alter... Jul 30 2020, 06:46 PM
SKL1 I saw 115 on the car thermometer today but I sure ... Jul 30 2020, 08:42 PM
76-914
I saw 115 on the car thermometer today but I sure... Jul 31 2020, 03:27 PM
ibmiked Will it keep up with a Saratoga Top in summer? ... Jul 31 2020, 08:55 AM
wes
Will it keep up with a Saratoga Top in summer? ... Jul 31 2020, 09:55 AM
Cairo94507 I am destined to sweat. :beer2: Jul 31 2020, 10:02 AM
horizontally-opposed Watching the development of these systems with kee... Jul 31 2020, 10:44 AM
tygaboy Does anyone know which evaporator they're hidi... Jul 31 2020, 06:19 PM
76-914
Does anyone know which evaporator they're hid... Jul 31 2020, 06:26 PM
GregAmy There are effective ways of storing and managing v... Aug 3 2020, 07:24 AM
Steve
There are effective ways of storing and managing ... Aug 3 2020, 08:11 AM
76-914 The cabin temp got down to 77-78F in a fairly forg... Aug 3 2020, 09:56 AM
Jonny Retrofit
The cabin temp got down to 77-78F in a fairly for... Aug 3 2020, 10:49 AM
Hoghead
The cabin temp got down to 77-78F in a fairly fo... Aug 4 2020, 10:05 PM
Coondog Was at PMS yesterday for a little work and to get ... Apr 8 2021, 11:04 AM
Steve
Was at PMS yesterday for a little work and to get... Apr 8 2021, 11:27 AM
mepstein When I talked to Johny about setting it up in a 91... Apr 8 2021, 12:04 PM
Cairo94507 @Coondog - Darn you. I am seriously looking forw... Apr 8 2021, 12:23 PM
Coondog
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 8 2021, 03:17 PM
rgalla9146 For me ?
Compressor up front, massive ... Apr 8 2021, 03:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 11:02 AM |
