| Coondog |
Jul 28 2020, 10:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California
| 914forme |
Jul 30 2020, 07:10 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
96a just means you will be hitting the backup storage, battery for the additional Amps. That is going to take a serious wire #4 if it is all copper, and #2 if it is an aluminum or AL - copper clad.
Example Never used the product just showing an example to make it easier on the next person. Now time to pop the (IMG:style_emoticons/default/popcorn[1].gif) |
| 76-914 |
Jul 30 2020, 08:37 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
96a just means you will be hitting the backup storage, battery for the additional Amps. That is going to take a serious wire #4 if it is all copper, and #2 if it is an aluminum or AL - copper clad. Example Never used the product just showing an example to make it easier on the next person. Now time to pop the (IMG:style_emoticons/default/popcorn[1].gif) Could be and I'm interested to see just like the rest of us, Stephan. Mark said his experience with them is that they are marginal which leads me to suspect they might require running on high a good amount of the time. Keith's unit will mount within 2-3ft of his battery which is also located in the front, so that helps with the wire size. An advantage that Keith will have over the units that Mark has experienced is the dry climate his will operate in. In skimming over the data for that brand unit I notice it is used for the sleeping area in a Semi Cab which, to me, would indicate night usage. There are however several larger units they sell and some of them surely can handle severe conditions, i.e. TX, OK, LA, FL, etc. I'd like to see how they perform in the heat of the day as well. Keith is a sharp cookie so I'm sure he'll cover all of the bases. So fingers crossed for his success. (IMG:style_emoticons/default/beerchug.gif) |
Coondog Elec Air Cond Jul 28 2020, 10:32 PM
eric9144 That's pretty slick, did that go into the blue... Jul 28 2020, 11:30 PM
Coondog
That's pretty slick, did that go into the blu... Jul 29 2020, 07:08 AM
Matty900
That's pretty slick, did that go into the bl... Jul 29 2020, 10:41 AM
Cairo94507 Hi Greg, I am watching for this too. I would love... Jul 29 2020, 06:20 AM
JmuRiz eeeeeexcellent Guess I should get a high power al... Jul 29 2020, 10:59 AM
mepstein They are great units but when you tell people they... Jul 29 2020, 11:28 AM
IronHillRestorations You've got to have a very high output alternat... Jul 29 2020, 11:28 AM
You've got to have a very high output alterna... Jul 29 2020, 11:29 AM
Cairo94507 Me- Long pause....... :beer2: Jul 29 2020, 11:29 AM
nditiz1 For any one with a 911 there is a group buy schedu... Jul 29 2020, 12:54 PM
RFoulds If its the same system that is currently available... Jul 29 2020, 02:49 PM
If its the same system that is currently availabl... Jul 29 2020, 03:03 PM
76-914 Someone here is doing an elec AC in his 6. It will... Jul 29 2020, 03:16 PM
GregAmy Heat doesn't work well in winter, A/C is too e... Jul 29 2020, 03:49 PM
rgalla9146 Many are interested in this.
I wish there wer... Jul 29 2020, 05:31 PM
Steve Keith and I are playing around with different opti... Jul 29 2020, 06:31 PM
76-914
Keith and I are playing around with different opt... Jul 29 2020, 10:02 PM
Jonny Retrofit
Keith and I are playing around with different opt... Aug 1 2020, 04:26 PM
76-914
Keith and I are playing around with different op... Aug 2 2020, 12:44 PM
Jonny Retrofit
Our system does not rely on 'ram air' fo... Aug 3 2020, 06:15 AM
Steve
Our system does not rely on 'ram air' f... Aug 3 2020, 07:07 AM
914Toy I will be collecting pics along this technical jou... Jul 30 2020, 08:30 AM
Luke M :popcorn:
I need a/c in my 6 too. I'll be ke... Jul 30 2020, 08:49 AM
Bleyseng For a 4 cylinder then sourcing a 70amp bus alterna... Jul 30 2020, 09:26 AM
Steve
For a 4 cylinder then sourcing a 70amp bus altern... Jul 30 2020, 10:36 AM
914e
For a 4 cylinder then sourcing a 70amp bus alter... Jul 30 2020, 06:46 PM
SKL1 I saw 115 on the car thermometer today but I sure ... Jul 30 2020, 08:42 PM
76-914
I saw 115 on the car thermometer today but I sure... Jul 31 2020, 03:27 PM
ibmiked Will it keep up with a Saratoga Top in summer? ... Jul 31 2020, 08:55 AM
wes
Will it keep up with a Saratoga Top in summer? ... Jul 31 2020, 09:55 AM
Cairo94507 I am destined to sweat. :beer2: Jul 31 2020, 10:02 AM
horizontally-opposed Watching the development of these systems with kee... Jul 31 2020, 10:44 AM
tygaboy Does anyone know which evaporator they're hidi... Jul 31 2020, 06:19 PM
76-914
Does anyone know which evaporator they're hid... Jul 31 2020, 06:26 PM
GregAmy There are effective ways of storing and managing v... Aug 3 2020, 07:24 AM
Steve
There are effective ways of storing and managing ... Aug 3 2020, 08:11 AM
76-914 The cabin temp got down to 77-78F in a fairly forg... Aug 3 2020, 09:56 AM
Jonny Retrofit
The cabin temp got down to 77-78F in a fairly for... Aug 3 2020, 10:49 AM
Hoghead
The cabin temp got down to 77-78F in a fairly fo... Aug 4 2020, 10:05 PM
Coondog Was at PMS yesterday for a little work and to get ... Apr 8 2021, 11:04 AM
Steve
Was at PMS yesterday for a little work and to get... Apr 8 2021, 11:27 AM
mepstein When I talked to Johny about setting it up in a 91... Apr 8 2021, 12:04 PM
Cairo94507 @Coondog - Darn you. I am seriously looking forw... Apr 8 2021, 12:23 PM
Coondog
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 8 2021, 03:17 PM
rgalla9146 For me ?
Compressor up front, massive ... Apr 8 2021, 03:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 11:02 AM |
