Best method to check your clutch cable tube, should it move @ all with pedal depressed? |
porschetub |
Jul 28 2020, 05:52 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As I have my g/box popping out of 4th gear I'am lost for a reason as everything has been done externally,Tangerine bulkhead bush, x 2 shift rod uni-joints and double oilite console bushes.
Shifts all other gears fine and down changes fine however have issues with a new cable that has needed constant adjustment since fitted it after a short time so thinking now the tube is moving in the tunnel due to the mounts breaking further. Thanks to a fellow NZ member on here I have got the contact for the leading guy in my country that works on these transmissions but TBO don't want to send it to him for assessment if its not an internal problem and can least afford to do that. Will add that I have new clutch with clutch throw out arm rebushed and new mounts but when last checked I noticed the tube was moving a little with pedal depressed. TIA. |
76-914 |
Jul 30 2020, 04:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If it tore away from the firewall it will be obvious when viewing from the engine compartment or the rear access cover. You'd probably have some scoring on the firewall and/or the cable would be off to one side. IIRC. To determine if it was the middle brace I stuck a screwdriver through the bolt hole on psg side seatbelt attach point and had someone step on the clutch pedal. I'd forget my arse if it wasn't attached. If you run into a problem checking there LMK and I'll pull the carpet back to check how I did the repair. It's been a couple of years and it's on the lift. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 02:49 PM |
