> Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1
76-914
post Jun 28 2020, 08:36 PM
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
flmont
post Jul 23 2020, 01:45 PM
Man...That is so perfect !!
post Aug 2 2020, 12:16 PM
QUOTE(flmont @ Jul 23 2020, 12:45 PM) *
You jinxed me Frank! JK, I made a dumb assed mistake and corrections were in order so hence the hiatus. I left off thinking only the trans hanger was left to do. WRONG!
As I installed the clutch after placing the engine in the cradle I discovered the engine was not centered upon the cradle. I had also placed the reinforcement plate on the backside of the mount which would have acted as a scoop for dirt and grime. It should have been placed on the front side AND NOT welded to the tube on the bottom. That would have collected water and led to rust eventually (IMG:style_emoticons/default/WTF.gif) How in the Hell did I manage that. It was 1.5" off center. (IMG:style_emoticons/default/headbang.gif) Quien es el burro? So I cut off the mounts to made new ones and I'm glad that I did. I had varied from my original design and encountered a mounting problem as a result. By mounting the U shaped saddles more closely together I took away the length needed for the slot required. The slot allows for the angle of the mounting bolt on the OEM motor mount . I could have mounted the rubber OEM mount on the cradle first then attached the OEM mount to the engine but since I was making another set I now placed the U saddles far enough apart to allow for the lengthening of the slot. In doing so I reduced the process for fabricating the saddles. If you've already cut the U saddles per my earlier description your alright. You just need to mount the OEM mount to the cradle before mounting the engine.
Looking at the pics below you will see that one 4x4 plate gives you all 4 saddles less cutting and end up being the correct length needed. It also gives a little more material for welding to the tube towards the top of the U.
Welded in place.
The brace correctly positioned facing the front and with a gap that will allow water/sludge to drain and not collect.
Braces in place.
Since we can't see inside the tube I added another element to avoid rusting on the inside. The Schroeder valve allowed me to air test my welds. If air can't seep out moisture cannot seep in. (IMG:style_emoticons/default/shades.gif) You'll need to drill 2 small hole in each arm where the cross brace welds to it in order to get a test on the entire cradle. The Schroeder valve will be removed and plugged later. I thought it could act as an "air tank" but there isn't enough volume to inflate a tire. (IMG:style_emoticons/default/sad.gif) Now back to where I left off before I discovered my (IMG:style_emoticons/default/sheeplove.gif) up. To be continued.................
76-914   Re-Conversion of a '70 914   Jun 28 2020, 08:36 PM
tygaboy   Yaaaa! Can't wait to see this one come (ba...   Jun 28 2020, 09:31 PM
76-914   Yaaaa! Can't wait to see this one come (b...   Jun 30 2020, 04:52 PM
EdwardBlume   Love those Boxster rims. 70 was a good year. I kno...   Jun 28 2020, 09:35 PM
76-914   Love those Boxster rims. 70 was a good year. I kn...   Jun 30 2020, 04:53 PM
76-914   I've seen several requests for cradles in the ...   Jun 30 2020, 05:44 PM
flmont   What are u thinking price wise on that 901 , Than...   Jun 30 2020, 07:02 PM
76-914   What are u thinking price wise on that 901 , Tha...   Jun 30 2020, 07:25 PM
flmont   Sold..! TY   Jun 30 2020, 07:36 PM
76-914   Sold..! TY PM sent   Jun 30 2020, 08:05 PM
flmont   its still the same I did buy 914forme's crad...   Jun 30 2020, 07:40 PM
flmont   I do need to read ChrisH,..posting on the heater c...   Jun 30 2020, 07:44 PM
76-914   OK, back on track. If you plan to use 4130 chromol...   Jul 3 2020, 06:11 PM
tygaboy   METAL!!!! :headbanger: So cool ...   Jul 3 2020, 06:53 PM
76-914   Go ahead and remove your old hardware from the fro...   Jul 3 2020, 07:24 PM
808 WRX   Once it's is secure be sure the section past ...   Jul 6 2020, 01:39 PM
76-914   Once it's is secure be sure the section past...   Jul 6 2020, 09:51 PM
76-914   Now return the piece in place and hold the newly c...   Jul 3 2020, 08:08 PM
Andyrew   :trophy: :popcorn: :welder: Awesome!!...   Jul 6 2020, 01:45 PM
tygaboy   :trophy: :popcorn: :welder: Awesome!...   Jul 6 2020, 02:24 PM
914forme   Love the low tech cradle build. The roll of tap...   Jul 6 2020, 02:32 PM
JRust   Looks great Kent! Love to see the step by step...   Jul 6 2020, 08:40 PM
2mAn   Love it. I could hear the garage cursing because I...   Jul 6 2020, 09:02 PM
76-914   :trophy: :popcorn: :welder: Awesome!...   Jul 6 2020, 10:04 PM
andys   This is what I did for my cradle in case it helps....   Jul 7 2020, 11:24 AM
76-914   This is what I did for my cradle in case it helps...   Jul 7 2020, 12:59 PM
76-914   Round 4; I was able to steal away for 2 hours this...   Jul 7 2020, 09:38 PM
76-914   OK, things are fixing to get wordy so bare with me...   Jul 8 2020, 03:29 PM
76-914   The Poltergeist is back. That last pic isn't s...   Jul 8 2020, 03:37 PM
76-914   Now for the 3/16" reinforcing pieces. This ru...   Jul 8 2020, 03:58 PM
76-914   And this is why I wear an apron when weld...   Jul 8 2020, 04:06 PM
euro911   Looking good, Kent. (subscribed)   Jul 8 2020, 04:32 PM
Andyrew   That looks STOUT! Might be going a bit overboa...   Jul 9 2020, 08:45 AM
76-914   Looking good, Kent. (subscribed) @[url=http://ww...   Jul 9 2020, 08:04 PM
euro911   [quote name='euro911' post='2832137' date='Jul 8 2...   Jul 11 2020, 10:02 PM
rhodyguy   That's a very handsome table you have for your...   Jul 11 2020, 07:03 PM
76-914   That's a very handsome table you have for you...   Jul 12 2020, 12:47 PM
76-914   The steel spacers or bushing stock arrived last we...   Jul 22 2020, 05:27 PM
euro911   You make it look like you know what you're doi...   Jul 22 2020, 06:01 PM
76-914   Now it's time to take this cross member tube a...   Jul 22 2020, 06:32 PM
76-914   Now remove the cradle from the car and place it up...   Jul 22 2020, 07:03 PM
flmont   Man...That is so perfect !!   Jul 23 2020, 01:45 PM
76-914   Man...That is so perfect !! You jinxe...   Aug 2 2020, 12:16 PM
76-914   And then there was this Heatwave........There went...   Aug 24 2020, 09:20 PM
76-914   Oops. I didn't show any pics of the final crad...   Aug 24 2020, 09:28 PM
euro911   Since you drilled holes for the Schroeder valves, ...   Aug 24 2020, 10:12 PM
914forme   :agree: or other coating of your choice. Fluid Fi...   Aug 25 2020, 06:39 AM
ValcoOscar   Kent- :wavebye: I'm here for you if you de...   Aug 25 2020, 09:48 AM
76-914   Kent- :wavebye: I'm here for you if you d...   Aug 25 2020, 05:03 PM
76-914   Since you drilled holes for the Schroeder valves,...   Aug 25 2020, 05:05 PM
76-914   I did get it in primer this morning. Hopefully I c...   Aug 25 2020, 05:10 PM
76-914   Dressed her up with a new coat this morning. I...   Aug 26 2020, 03:00 PM
808 WRX   :cheer: Looking good! :beer2:   Aug 26 2020, 03:22 PM
76-914   Thx, They're like women."They all look go...   Aug 27 2020, 03:14 PM
76-914   So, before the afternoon heat crept in I was able ...   Aug 27 2020, 03:33 PM
rmarx   Great thread! Thank you for posting all the de...   Sep 11 2020, 05:41 PM
76-914   Sorry I'm late getting back to you @rmarx . J...   Sep 16 2020, 05:37 PM
Steve   Impressive skills Kent!! As Ferdinand sai...   Sep 16 2020, 07:05 PM
rnellums   Great work Kent. When I rebuilt my pedal assembly ...   Sep 16 2020, 07:44 PM
mgp4591   Great work Kent. When I rebuilt my pedal assembly...   Sep 17 2020, 10:48 AM
euro911   You master fabricator, you :headbanger:   Sep 17 2020, 12:04 AM
ValcoOscar   Kent- You are officially a WORLDLY MacGyver! ...   Sep 17 2020, 11:24 AM
76-914   Impressive skills Kent!! As Ferdinand sa...   Sep 17 2020, 07:19 PM
76-914   Picking up where I left off. Here is a pic of the ...   Sep 22 2020, 01:48 PM
76-914   And a couple of "finished product" shots...   Sep 22 2020, 01:50 PM
76-914   Half shafts are out. After cut to length & the...   Sep 24 2020, 04:34 PM
76-914   The first thing I did was remove the 4 bolts from ...   Sep 30 2020, 01:26 PM
914Subaru   Kent, This new project is looking good. I was ins...   Oct 1 2020, 07:28 PM
76-914   Kent, This new project is looking good. I was in...   Oct 2 2020, 10:20 AM
Gint   Excellent work Kent! Subscribed @76-914 [q...   Oct 5 2020, 10:05 PM
Montreal914   Nice shifter location. :) How far back from the ...   Oct 1 2020, 09:24 PM
76-914   Nice shifter location. :) How far back from the...   Oct 2 2020, 10:26 AM
76-914   Nice shifter location. :) How far back from the...   Oct 29 2020, 04:27 PM
76-914   The fuel hose arrived this weekend so I was able t...   Oct 5 2020, 06:30 PM
Montreal914   Thank you for the added shifter information. Looki...   Oct 5 2020, 08:34 PM
euro911   Hey, Mike ( @[url=http://www.914world.com/bbs2/ind...   Oct 5 2020, 11:31 PM
Gint   Hey, Mike ( @[url=http://www.914world.com/bbs2/in...   Oct 6 2020, 04:40 PM
76-914   Future   Oct 24 2020, 05:05 PM
76-914   I thought I should post this for any of you guys t...   Oct 26 2020, 09:23 PM
Montreal914   Thank you :beer2: That is very similar to the 91...   Oct 29 2020, 08:47 PM
76-914   It's been a few weeks and only a few items rem...   Nov 9 2020, 06:04 PM
76-914   Then clamp together and weld. I use this term weld...   Nov 9 2020, 06:09 PM
76-914   All of the plumbing is completed and tied in with ...   Nov 9 2020, 06:25 PM
FL 000   No idea how I have missed this thread until now. N...   Nov 9 2020, 06:56 PM
914GTSTI   Thanks for all the great Ideas ! Your the MAN ...   Dec 1 2020, 10:11 PM
Chris H.   Looks great Kent! What size radiator hoses di...   Dec 1 2020, 10:33 PM
76-914   Looks great Kent! What size radiator hoses d...   Dec 2 2020, 04:50 AM
Chris H.   Looks great Kent! What size radiator hoses ...   Dec 2 2020, 01:16 PM
76-914   I have some catching up to do here. I received my ...   Dec 11 2020, 11:56 AM
rhodyguy   Party ON!   Dec 11 2020, 12:08 PM
Mueller   Nice job, might have to borrow a few of your desig...   Dec 11 2020, 02:12 PM
76-914   Thx Mike. Well, I went to way much trouble install...   Dec 25 2020, 05:09 PM
76-914   If it ain't one thing it's two. I've b...   Jan 12 2021, 10:40 AM
BillJ   Very cool build and thanks for sharing it! Ar...   Jan 12 2021, 11:17 AM
76-914   Very cool build and thanks for sharing it! A...   Jan 12 2021, 07:01 PM
rhodyguy   How many turbos on the replacement 6? 2?   Jan 12 2021, 07:06 PM
Chris914n6   I'd check the harness too to make sure that...   Jan 12 2021, 08:46 PM
76-914   I'd check the harness too to make sure that...   Jan 13 2021, 10:21 AM
76-914   Well it's been 5 weeks and I wish I were furth...   Feb 24 2021, 09:10 PM
76-914   So the newest engine runs great, pulls strong and ...   Feb 24 2021, 09:34 PM
- Lo-Fi Version Time is now: 21st November 2026 - 03:20 AM
