> Elec Air Cond, PMS
Coondog
post Jul 28 2020, 10:32 PM
I have been waiting for Patrick Motor Sports to start installing this in 914s. I have reached out to them and will pass on any info given. Not a fan of the vent set up in this Patrick car but anything custom could be done in there shop.
Steve
post Jul 29 2020, 06:31 PM
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....??
This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit.
Jonny Retrofit
post Aug 1 2020, 04:26 PM
QUOTE(Steve @ Jul 30 2020, 01:31 AM) *
I have been emailing with Keith.
We started ‘playing’ with these compressors five years ago. What they don’t tell you is that the current used is not just proportional to compressor speed, it is drastically affected by system pressure which of course is related to ambient temperature.
It is not the case that low speed = 40A, high speed = 90A period. It varies wildly with ambient. Also, because the alternator output drops at idle, the voltage drops and the current rises which causes what we call the ‘death spiral’, which results in compressor shut off. In the race car world where these units have been used, it has taken cars out of races due to low voltage.
It took 2 years of development and testing to devise a robust software control strategy to safely manage the power required dynamically. Our ECU is always trying to minimise the power used against the cooling required ( which it does using temperature sensors to assess demand ). The ECU drives the compressor at variable speeds to regulate the current consumption. We are still fine tuning the software and we release software updates based on user feedback (thanks to our customers and our Arizona and Florida partners).
In a nutshell, What you are paying for is our blood, sweat and tears in developing a control system that allows the compressor to ‘play nice’, not drain your battery, not roast your alternator.
Although the compressor we supply might look like others available online, it is not the same unit.
post Aug 2 2020, 12:44 PM
QUOTE(Jonny Retrofit @ Aug 1 2020, 03:26 PM) *
Hows does it perform @ temps above 35C? Hi Way/ City? In Southern California traffic is stop n go. More stopping than going. Same goes for Austin, Dallas and Miama (IMG:style_emoticons/default/beerchug.gif)
Coondog   Elec Air Cond   Jul 28 2020, 10:32 PM
eric9144   That's pretty slick, did that go into the blue...   Jul 28 2020, 11:30 PM
Coondog   That's pretty slick, did that go into the blu...   Jul 29 2020, 07:08 AM
Matty900   That's pretty slick, did that go into the bl...   Jul 29 2020, 10:41 AM
Cairo94507   Hi Greg, I am watching for this too. I would love...   Jul 29 2020, 06:20 AM
JmuRiz   eeeeeexcellent Guess I should get a high power al...   Jul 29 2020, 10:59 AM
mepstein   They are great units but when you tell people they...   Jul 29 2020, 11:28 AM
IronHillRestorations   You've got to have a very high output alternat...   Jul 29 2020, 11:28 AM
mepstein   You've got to have a very high output alterna...   Jul 29 2020, 11:29 AM
Cairo94507   Me- Long pause....... :beer2:   Jul 29 2020, 11:29 AM
nditiz1   For any one with a 911 there is a group buy schedu...   Jul 29 2020, 12:54 PM
RFoulds   If its the same system that is currently available...   Jul 29 2020, 02:49 PM
mepstein   If its the same system that is currently availabl...   Jul 29 2020, 03:03 PM
76-914   Someone here is doing an elec AC in his 6. It will...   Jul 29 2020, 03:16 PM
GregAmy   Heat doesn't work well in winter, A/C is too e...   Jul 29 2020, 03:49 PM
rgalla9146   Many are interested in this. I wish there wer...   Jul 29 2020, 05:31 PM
Steve   Keith and I are playing around with different opti...   Jul 29 2020, 06:31 PM
76-914   Keith and I are playing around with different opt...   Jul 29 2020, 10:02 PM
Jonny Retrofit   Keith and I are playing around with different opt...   Aug 1 2020, 04:26 PM
76-914   Keith and I are playing around with different op...   Aug 2 2020, 12:44 PM
Jonny Retrofit   Our system does not rely on 'ram air' fo...   Aug 3 2020, 06:15 AM
Steve   Our system does not rely on 'ram air' f...   Aug 3 2020, 07:07 AM
914forme   96a just means you will be hitting the backup stor...   Jul 30 2020, 07:10 AM
76-914   96a just means you will be hitting the backup sto...   Jul 30 2020, 08:37 AM
914Toy   I will be collecting pics along this technical jou...   Jul 30 2020, 08:30 AM
Luke M   :popcorn: I need a/c in my 6 too. I'll be ke...   Jul 30 2020, 08:49 AM
Bleyseng   For a 4 cylinder then sourcing a 70amp bus alterna...   Jul 30 2020, 09:26 AM
Steve   For a 4 cylinder then sourcing a 70amp bus altern...   Jul 30 2020, 10:36 AM
914e   For a 4 cylinder then sourcing a 70amp bus alter...   Jul 30 2020, 06:46 PM
SKL1   I saw 115 on the car thermometer today but I sure ...   Jul 30 2020, 08:42 PM
76-914   I saw 115 on the car thermometer today but I sure...   Jul 31 2020, 03:27 PM
ibmiked   Will it keep up with a Saratoga Top in summer? ...   Jul 31 2020, 08:55 AM
wes   Will it keep up with a Saratoga Top in summer? ...   Jul 31 2020, 09:55 AM
Cairo94507   I am destined to sweat. :beer2:   Jul 31 2020, 10:02 AM
horizontally-opposed   Watching the development of these systems with kee...   Jul 31 2020, 10:44 AM
tygaboy   Does anyone know which evaporator they're hidi...   Jul 31 2020, 06:19 PM
76-914   Does anyone know which evaporator they're hid...   Jul 31 2020, 06:26 PM
GregAmy   There are effective ways of storing and managing v...   Aug 3 2020, 07:24 AM
Steve   There are effective ways of storing and managing ...   Aug 3 2020, 08:11 AM
76-914   The cabin temp got down to 77-78F in a fairly forg...   Aug 3 2020, 09:56 AM
Jonny Retrofit   The cabin temp got down to 77-78F in a fairly for...   Aug 3 2020, 10:49 AM
Hoghead   The cabin temp got down to 77-78F in a fairly fo...   Aug 4 2020, 10:05 PM
Coondog   Was at PMS yesterday for a little work and to get ...   Apr 8 2021, 11:04 AM
Steve   Was at PMS yesterday for a little work and to get...   Apr 8 2021, 11:27 AM
mepstein   When I talked to Johny about setting it up in a 91...   Apr 8 2021, 12:04 PM
Cairo94507   @Coondog - Darn you. I am seriously looking forw...   Apr 8 2021, 12:23 PM
Coondog   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 8 2021, 03:17 PM
rgalla9146   For me ? Compressor up front, massive ...   Apr 8 2021, 03:46 PM
- Lo-Fi Version Time is now: 14th November 2026 - 11:02 AM
