| aoor0708 |
Jul 27 2020, 10:29 AM
Newbie ![]() Group: Members Posts: 6 Joined: 29-November 19 From: Belgium Member No.: 23,684 Region Association: None |
Have recently bought a 914 - 1972 - date 12/7 - 1689 cc which is running terrible and produces a gasolie smell. Have tried to tune with the existing ECU and Pressure Unit, but no good results. Found out the ECU has a numer 0280-000-037 and the Pressure Unit 311-906-051B
Presume these unit are not correct for this engine. Anybody could provide me with ECU and Pressure Unit numbers that fit this engine ? (IMG:style_emoticons/default/sad.gif) |
| nordfisch |
Aug 3 2020, 04:58 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Have recently bought a 914 - 1972 - date 12/7 - 1689 cc which is running terrible and produces a gasolie smell. Have tried to tune with the existing ECU and Pressure Unit, but no good results. Found out the ECU has a numer 0280-000-037 and the Pressure Unit 311-906-051B Presume these unit are not correct for this engine. Anybody could provide me with ECU and Pressure Unit numbers that fit this engine ? (IMG:style_emoticons/default/sad.gif) Hi, the ECU is the correct one. Your MPS is false - meant for the VW type 3 1600 ccm. You need the 022906051E that was installed to VW type 4 (411) and the 914. Bosch # is 0 280 100 049, search for 0280100049 and you will find several used units. I wish you find a unit that wasn't misadjusted and with the diaphragm not broken. Check this when you receive the part. Follow the link Beatnavy posted. A MPS with broken diaphragm cannot work correctly. Regards Norbert |
aoor0708 Which ECU unit for 1.7 ltr - 1972 (European) Jul 27 2020, 10:29 AM
scottthephotog This site is a great resource for DJet troubleshoo... Jul 27 2020, 10:41 AM
nordfisch
...The MPS can be calibrated for each car though.... Aug 5 2020, 03:24 PM
BeatNavy You may have a slight mismatch on MPS / ECU. The ... Jul 27 2020, 10:56 AM
Bleyseng Check that the cht is the correct one and working ... Aug 3 2020, 07:08 PM
Frankvw Hi, yes your MPS is for a VW Type3 with Injection,... Aug 5 2020, 01:40 AM
Bleyseng No they are not all the same. Different springs an... Aug 5 2020, 06:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:29 PM |
