| porschetub |
Aug 8 2020, 07:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,200 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As per question,TIA
| bdstone914 |
Aug 8 2020, 07:49 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,424 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@porschetub
Carve out the inner lip with a knife. Screw in a 14mm lug nut and it will pull it right out. |
porschetub Speedo angle drive oil seal removal Aug 8 2020, 07:11 PM
porschetub
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 8 2020, 09:58 PM
Mikey914 If the drive is out you can get behind it easy eno... Aug 9 2020, 01:24 AM
Frankvw listen, there is a very easy trick to get it out. ... Aug 9 2020, 04:01 AM
Tdskip
listen, there is a very easy trick to get it out.... Aug 9 2020, 05:56 AM
porschetub Saga continues,found a fair amount of wear on the ... Aug 10 2020, 05:33 PM
bdstone914 @porschetub
Note the erosion on the aluminum wea... Aug 10 2020, 10:01 PM
Mikey914 Your more likely to have fluid leak at the worn se... Aug 10 2020, 09:28 PM
porschetub Thanks guys,my reason for removing it was the chan... Aug 11 2020, 01:42 PM
porschetub Topped off the trans only a small amount to top sp... Aug 12 2020, 11:20 PM
Frankvw porschetub, you asked for comments, here mine:
... Aug 13 2020, 01:24 AM
porschetub
... Aug 13 2020, 03:01 PM
brian minson I had to replace the seal on mine a few months bac... Aug 13 2020, 04:06 PM
porschetub
I had to replace the seal on mine a few months ba... Aug 20 2020, 06:48 PM
porschetub Continuing on or "while you are in there... Aug 24 2020, 07:15 PM
porschetub
Continuing on or "while you are in there... Aug 26 2020, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 09:19 AM |
